Bend a coat hanger back and forth enough times and voila...
Instead of the load being spread out over a larger area you effectively have two points of contact where the shock bolts to the lower arm.
Thanks for your input guys. Helped me make up my mind.
I'm running the VanSteel setup which includes tube A-Arms upper & lower, and off set T/As in the rear & no leaf spring. QA1s coilovers on all four corners with Hyperco springs. It's a great set up.
