Headlamp Flashing
Old Nov 12, 2005 | 07:25 AM
JHT's Avatar
JHT
7th Gear
Default Headlamp Flashing
First post from across the pond here in England, Have just got a 75 Head lights on dip beam is fine but sometimes when you go to main beam head lights go out then come on again it dosent happen all the time but now and again eney ideas? whats goin on, I am not very good at finding elec faults
Cheers John
Old Nov 12, 2005 | 09:57 AM
goinbroke's Avatar
goinbroke
Possibly the low beam/high beam switch itself is bad??
Old Nov 12, 2005 | 10:00 AM
fl_rider's Avatar
fl_rider
Sounds like a loose or bad connection somewhere in the circuit for the High beams.
High and Low beams use the same ground so if it was a ground problem you would see the same thing on Low beams as well
Old Nov 12, 2005 | 05:07 PM
1Z87L8's Avatar
1Z87L8
may also just be the filament in the headlight bulb itself.
i had one that used to go out and if i smacked on it would make
contact and work again until i hit a hard enough bump in the road
to make it go out again.
To Headlamp Flashing
