oil pan question
Old Nov 12, 2005 | 10:56 AM
jlaw68's Avatar
jlaw68
Default oil pan question
anyone ever pulled the oil pan while the engine was in the car. is there enough clearance not to have to jack up the engine?
Old Nov 12, 2005 | 11:46 AM
kdf1986's Avatar
kdf1986
I asked this question about my 73 oil pan replacement. The answer I got was that it can be done, but part of the steering linkage needs to be removed in order to drop the pan. My car is a big block, so I dont know if yours would be any different.
kdf
Old Nov 12, 2005 | 11:50 AM
carl a's Avatar
carl a
i have had mine off a few times, a 383 motor, we had to move the steering to get it off
Old Nov 12, 2005 | 12:13 PM
Solid LT1's Avatar
Solid LT1
Unbolt the idler arm on the passenger side and drop the pan. Easily done!
Old Nov 12, 2005 | 12:16 PM
GDaina's Avatar
GDaina
don't forget to remove the oil filter as well...on the BB the filter has to be removed, maybe also on the SB
Old Nov 12, 2005 | 12:24 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
I just asked the same question last week about my 72BB. Yes, you need to remoce the linkage, and can probably remove it from the idler arm side and swing it awat, no firther jacking is required becuase there no crossmember under it like othe GM frames.
Old Nov 12, 2005 | 12:53 PM
jlaw68's Avatar
jlaw68
i had the feeling that i didnt have to raise up the engine, it looked like i would have enough clearance when i was changing the timing chain and cover last weekend. now it looks like oil pan gasket is leaking.
Old Nov 12, 2005 | 01:14 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
it definitely helps to have the oil filter pulled on a small block when you put it back on...
Old Nov 12, 2005 | 01:39 PM
73jst4fun's Avatar
73jst4fun
[QUOTE=Solid LT1]Unbolt the idler arm on the passenger side and drop the pan. Easily done![/QUOTE
an easy job...
Old Nov 12, 2005 | 10:06 PM
redc3's Avatar
redc3
sb 78.... you dont have to remove anything to take the pan off
Old Nov 12, 2005 | 10:52 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Doesn't get any easier than on a Vette. If you have a crossover pipe that's gotta go. Drop the steering at the idler arm, disconnect power steering cylinder at the frame mount.
Headers, easier yet.
Starter and flywheel cover removal helps.
Mike
Old Nov 12, 2005 | 11:30 PM
comp's Avatar
comp
good pic's
To oil pan question
