Can a differential lock?
Old Nov 13, 2005 | 12:30 PM
Cookwithvette's Avatar
Cookwithvette
Default Can a differential lock?
I mean, I know the whole shebang can seize but I'm wondering if it's possible for the differential to fail in such a way that both wheels are locked into turning at the same rate.
I've noticed that as I turn (especially at low speeds) I get a lot of tire squeal. Also, when wet it has been extra... scary.
Old Nov 13, 2005 | 12:41 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Possibly. Basically its like a spool then.
Old Nov 13, 2005 | 01:36 PM
BigBlockk's Avatar
BigBlockk
Get one of these then drive the car in slow, tight figure 8's in an empty concrete parking lot. Hopefully this will force some new lubricant into the clutches and get them to function properly. This is for '68 to '79 cars.
http://www.ecklers.com/product.asp?d...QAR4L69ERV81D6
This one is for '80 to '82.
BigBlockk
Later.....
Old Nov 13, 2005 | 01:40 PM
Gordonm's Avatar
Gordonm
I run two bottle of additive in mine. Never had a problem. If the rear is setup to tight you can also get this popping sound. This will usually happen on a new rear though. Try the fluid first. If not your posi might have to be rebuilt.
Old Nov 13, 2005 | 01:49 PM
Cookwithvette
I actually have an extra bottle of gm lube. I changed the fluid last summer and used one bottle, I'll throw the other in.
Old Nov 13, 2005 | 10:00 PM
GTR1999's Avatar
GTR1999
If it's like the differential I opened the other day it could. This is the worse looking diff I worked on. I don't think the oil was changed since it left St Louis in '69! Everything inside,including the posi clutches, was coverd in black coating like powder coating. I spent about 6 hours cleaning this disgusting POS, but it's much better now
Stay tuned for future pic's of this messy AZZ end job!
Gary
Old Nov 14, 2005 | 01:19 AM
Cookwithvette
Hmm... that's not encouraging. The oil that came out of this thing last summer was a black, near-tar material. I just figured that's what old gear oil looked like.
Old Nov 14, 2005 | 02:19 AM
comp's Avatar
comp
and it still is driveable ??
Old Nov 14, 2005 | 03:57 PM
Cookwithvette
Oh yes. Only thing is it gets pretty flaky when the roads are wet and it squeals like a maniac in tight turns (particularly at low speeds).
To Can a differential lock?
