1980 Battery Drain
1. Had battery charged and checked- battery is good
2. Had alternator checked- was bad and and replaced it
3. Disconnected the positive battery end (black end) and completed connection with 12V light tester - light does not come on. Opened door and light comes on (wanted to verify process)
4 Performed light test right after installing fully charged battery and the weather was in the 60's
4. Radio and clock have no power and electric door locks do not work(was like this when I bought it)
Questions:
1.Could I still have a battery draw problem but it is low enough that the 12V light tester will not pick it up.
2.Do I need to use an amp/volt meter?
3.And if I use a meter -should it read 0 amps/volts or is there an amount that the vehicle should have.
4.Could a battery draw be delayed or be triggered by cold weather- humidity etc...(relay that comes on
???)I thought I had my problem resolved when the light did not come on.
Secondly, the red cable is positive, black cable is ground.
3. Should be around or under 10mA at idle I believe. Need to disconnect the positive end of the battery and close the circuit with the multi to figure this one out. Make sure the door is shut and the interior lights are off. (You can tell this is going to be fun, huh?)
4. Batteries get their butts kicked by cold weather, but I doubt cold weather is going to affect the internal electronics. It could be that your battery got its butt kicked from deep cycling and simply needs to be replaced. I have to install a new battery almost every year in the 78, it has an electrical gremlin that I don't really feel like chasing down, and if I am not diligent about driving it at least every other day - I will kill the battery. At that point, the car NEEDS to be driven at least every other day or the battery will die.
-Steve
When you say 10mA at idle- that is car off and doors shut - correct
So if I am more than 10mA -this is when I start pulling fuses to find the circuit - right.
Could there possibly be any circuits that do not go thru the fuse block? I think this car has an aftermarket alarm- does not work. There is this computer circuit board in a clear plastic case wired right next to the fuse block - do you know what this is??
Where do you put the kill switch at?
Thanks for the input
At the battery terminal. The example below is for a side-terminal battery, they also sell it for top-terminal batteries.
http://www.ecklers.com/product.asp?p...V16NJ9U3QP9217
Start pulling fuses until it quits. This didn't work for me...the drain in my '77 turned out to be some sort of internal short in the starter (not the solenoid, I changed it). After it really flaked out and I installed a BB502 GM mini-starter, my drain stopped.
Kill switches are a good idea for many reasons...I don't think that using them to stop a battery drain is one.
Darrel
Darrel
And when I said at idle, I actually did mean with the engine off and interior lights have already stopped.
Sorry about that.-Steve
1. Charged battery until the voltage read about 12V on the Volt meter
2. Closed doors and made sure all lights etc are off
3. disconnected battery and put ammeter in series. I measured 8.12mA. That seems ok
4. Opened one door and measured again and got a higher number (cannot remember how much), so I believe measured right.
5. Connected battery back up and tried to start the engine. My choke is locked up so had to crank a little longer than normal (we just got our first cold snap here in Michigan).
Heres where I think my problem is. After 1 maybe 2 tries the starter acted like it was not getting enough juice. It rotated the engine slightly and then click- click- click etc...
5. I rechecked the voltage at the battery and it still had 11V. Disconnected battery and still 8.12mA drain.
Is there a bad connection between my battery and starter, or is the starter just bad, or maybe the solenoid (I have heard people mention this, but not sure of the symptoms if it is bad).
Any thoughts.
Darrel
