Oil Pressure
Old Nov 15, 2005 | 12:21 PM
KyMagRed's Avatar
KyMagRed
Default Oil Pressure
Need some help. I have a 1978 with low miles. I wanted to flush the radiator and when I started the car I showed no oil pressure. I feel its the oil pressure sender but how do I make sure its not the oil pump or the gauge? The wire to the sender looks like I have a good connection. What next? Thanks T
Old Nov 15, 2005 | 12:36 PM
Gordonm's Avatar
Gordonm
Take the wire off the sender and put it to a ground. This should make the gauge go all the way to the right. Max oil pressure. If this works it is in the sending unit. If not you will have to start at the wire and trace to the gauge.
Old Nov 15, 2005 | 11:49 PM
comp's Avatar
comp
Old Nov 16, 2005 | 09:50 AM
KyMagRed's Avatar
KyMagRed
Thanks. I just tried to ground the wire but not sure I made good conact with the connector. I will get a clip and try again.
To Oil Pressure
