Refrigerant question
Old Nov 15, 2005 | 03:26 PM
Wrecked82's Avatar
Wrecked82
Default Refrigerant question
Does a small amount of R134A in an R12 system hurt?
Don't ask.
Old Nov 15, 2005 | 04:03 PM
PureSilver's Avatar
PureSilver
define a 'small amount'. it is like air- a small amount is less bad than a large amount. if it is 5% or less, maybe not. 50% or more, bad...
Old Nov 15, 2005 | 04:08 PM
Wrecked82's Avatar
Wrecked82
No, it would be probably more like the 5%.
Old Nov 15, 2005 | 05:55 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I believe the main diffence is the type of compressor oil used. I assume you ask because you can get R-134 at Auto Zone, but not R-12. IMO I wouldn't mix the two refridgerants.
Old Nov 15, 2005 | 08:42 PM
BARRY L-48's Avatar
BARRY L-48
I would not mix the two refrigerants as they compress different and you will not get a correct pressure and that will cause problems with cooling,could cause evaporator freeze up.
Old Nov 15, 2005 | 08:51 PM
kdf1986's Avatar
kdf1986
hello,
I found a thread that was posted by Zwede on this same topic.
I cut and pasted a comment that he made on the report.
kdf
http://www.corvetteforum.net/c3/zwed...c/retrofit.htm
Oil. R12 systems use 500 viscosity mineral oil. R134A systems use PAG oil. The two are not compatible. If mineral oil is used with R134A, it will not mix with the refrigerant, and the compressor will starve for oil and seize.
Old Nov 15, 2005 | 09:09 PM
Pete76Shark's Avatar
Pete76Shark
Post your question to this URL
http://www.autoacforum.com
Most of these guys are in the HVAC business
Old Nov 15, 2005 | 11:50 PM
comp's Avatar
comp
Old Nov 16, 2005 | 01:37 AM
Sprzout's Avatar
Sprzout
On this general topic...
When the time comes to get the A/C system running on our '74, we're thinking of just taking it to a shop to have the system charged and inspected, since we don't have the tools to fix it.
I'm assuming that any reputable shop should be able to replace it with R12 (assuming that's what's in the system), right? Or am I going to be stuck with replacing components of the system because R134a is the only thing that can be charged in an A/C system nowadays?
Old Nov 16, 2005 | 05:40 AM
Pete76Shark
They will give you two prices, one for R134a and one for R12.
HVAC shops can get as much R12 as they want.
Old Nov 16, 2005 | 06:14 AM
comp's Avatar
comp
the parts store's can't here,,,but i got 3 cases
To Refrigerant question
