Muncie 4 speed side cover Question???
Old Nov 15, 2005 | 05:01 PM
theandies's Avatar
theandies
Default Muncie 4 speed side cover Question???
How do you get the side cover back on? Does it need to be in a certain gear or what?
Old Nov 15, 2005 | 05:52 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I rebult mine several times, but that was years ago. I never remember having any problems with the side cover, just make sure the shift forks are lined up correctly and it should fit.
Old Nov 15, 2005 | 06:55 PM
wnjlt1's Avatar
wnjlt1
I just resealed the M21 this past summer. Gear selector hubs and forks were all in neutral then I lined up the forks to hubs and just wiggled the side cover on to the case. It was pretty easy so yes, make sure everything is lined up and the fork shafts are in the cover all the way.
Old Nov 15, 2005 | 07:25 PM
comp's Avatar
comp
neutral
Old Nov 15, 2005 | 07:52 PM
Kid Vette's Avatar
Kid Vette
I rebuilt mine about a year ago. As I recall it works best if the tranny is in second gear. Otherwise the shift fork hits the case. I believe moving the front slider towards the back puts the tranny in second. However I'm 53 and have had a couple of shots already tonight so somebody correct me if I'm wrong.
Old Nov 15, 2005 | 08:12 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I read the manual after I had mine apart too. shifter should be in second before removing the cover.
Old Nov 15, 2005 | 08:43 PM
vettepilot68's Avatar
vettepilot68
2nd gear! Goes on easy. Prob will go on in neutral, but I couldnt get it to very easily. 2nd gear, easy.
Old Nov 15, 2005 | 09:07 PM
wnjlt1's Avatar
wnjlt1
53? I bet your just a Kid @ heart.
Old Nov 15, 2005 | 09:09 PM
Gordonm's Avatar
Gordonm
It will go in in nuetral but much easier if in 2nd gear.
Old Nov 15, 2005 | 09:44 PM
Kid Vette's Avatar
Kid Vette
Actually I'm only a Kid at heart. Everywhere else is showing some wear and tear.
Old Nov 16, 2005 | 03:58 AM
Solid LT1's Avatar
Solid LT1
First right answer on the thread: Give that man a CIGAR! 2nd gear needs to be engaged to allow the sidecover to be reinstalled without a fight.
Old Nov 16, 2005 | 05:43 AM
theandies's Avatar
theandies
Thanks everyone! I can almost get it on in N. 2nd it is.
Old Nov 16, 2005 | 06:55 AM
comp's Avatar
comp
noted
Old Nov 16, 2005 | 12:17 PM
Kid Vette's Avatar
Kid Vette
Ahem! I believe if you review the thread you will see that it was I who was the first with the right answer. However I'm not a cigar smoker so light 'er up Jughead.
Old Nov 16, 2005 | 05:06 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Old Nov 17, 2005 | 12:27 AM
5speeds's Avatar
5speeds
Default How about the reason???
Although it was answered correctly, the reason the transmision must be in 2nd gear is to allow the 1-2 fork ( and all forks) to remain in the side cover and CLEAR the reverse idler boss in the main case.
Paul
Old Nov 17, 2005 | 12:08 PM
Kid Vette's Avatar
Kid Vette
Thanks for the input, Paul. I used your video when I rebuilt my M-20. I would highly recommend it to anyone with a Muncie whether you're planning to rebuild it yourself or not. I bought a couple of the "How to Rebuild a Muncie" sheets on Ebay; they were nowhere as useful as the video.
Old Jan 8, 2006 | 04:57 PM
collectskulls's Avatar
collectskulls
ok so dumb question if you have it all apart and it is not in 2nd how do you get in to 2nd so you can get the cover back on and please dont ask why i need to know
Old Jan 8, 2006 | 07:16 PM
collectskulls
ttt
To Muncie 4 speed side cover Question???
