High Compression Engine w/ Blower
Old Nov 17, 2005 | 11:00 PM
enkeivette's Avatar
enkeivette
Default High Compression Engine w/ Blower
Just out of curiosity, and I know lower compression motors are better for boost. But would it be possible to run a small roots blower on a motor with 10.2:1 compression and aluminum heads at a low boost setup and run 91 octane?
I see C5s with blowers all the time so I would assume that it's possible.
Old Nov 17, 2005 | 11:09 PM
big_G's Avatar
big_G
They are usually intercolled, and boost limited to 6 or 7 lbs. Alot of money for little boost, IMO. I am going to do a centrifugal Pro-Charger someday, and they want no more that 9:1 c/r max, using forged pistons of course. I'm gonna do 12 psi boost, blow-thru carbureted.
Old Nov 18, 2005 | 08:02 AM
pauvil's Avatar
pauvil
It's possible, your virtual compression is going to be very high depending on the boost you want to run, an intercooler for that is a must. As far as for the new motors, they have a very good ECU that can make adjustments for fueling/timing very fast. If your considering doing this I would look into an ECU of some kind, you'll be very prone to putting a piston out the side of your motor if you go lean.
Old Nov 18, 2005 | 04:21 PM
enkeivette's Avatar
enkeivette
So I'd need to go with a centrifugal blower and electronic fuel injection? Guess that means I'll use juice instead.
Old Nov 18, 2005 | 04:44 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
12 psi. This guy i know runs about 35 on his SB
Old Nov 18, 2005 | 09:08 PM
glen242's Avatar
glen242
What kind of (brand) of supercharger?
Old Nov 18, 2005 | 09:14 PM
pauvil's Avatar
pauvil
Yes, you can run very high boost depending on what your static compression is, the guys running high boost on the street are probabley around 8:1 , remember, unless your going all out racing you want to keep it reliable and practical. The key is to monitor you fuel delivery so you don't go lean, the more boost the higher the cylinder pressures and if the fuel is not right...BANG!! I ran 18psi on my 4 cylinder with 7.5:1 and would chew up mustangs, when I calibrated my ECU the fuel was compensated. Very good idea to run an EGT and AFR gauge.
Old Nov 19, 2005 | 07:39 AM
not a '76's Avatar
not a '76
You can run boost on 10:1.
but its meaner on the engine then making the same power with less CR and more boost.
and an EMS would be a good choice.
Old Nov 19, 2005 | 08:02 PM
Chuck Harmon's Avatar
Chuck Harmon
http://www.aquamist.co.uk/dc/coollin...el/jankel.html
The link above shows a guy using a Chevy small block with 10:1 compression and 10 pounds of boost. He makes 535net hp and 600+ pounds of torque. He uses water injection.
Chuck
To High Compression Engine w/ Blower
