Drive Axle U Joint Diagnosis
Old Nov 19, 2005 | 07:09 PM
1stC3Vette's Avatar
1stC3Vette
Default Drive Axle U Joint Diagnosis
My brothers '76 just got back on the road and we noticed a rather loud clunking noise behind the drivers seat. Sounds like the drive axle u joint is bad.
I raised up the rear and slightly rotated the tire/wheel to look for play and noticed some.
My question is, how hard is it to replace these u joints? Does anyone have some good instructions or is it straight forward. Do we replace both sides at the same time?
Thanks,
Dino
Old Nov 19, 2005 | 07:38 PM
GTR1999's Avatar
GTR1999
Dino I'll PM you some info,
Gary
Old Nov 20, 2005 | 09:07 AM
BerniesVette's Avatar
BerniesVette
Are you sure it's a u-joint and not the front rubber bushing for the differential? If it is worn out it will clunk when you start forward, backward or when shifting. Hope this helps.
Bernie
Old Nov 20, 2005 | 09:45 AM
sly vette's Avatar
sly vette
Check end play at the half shaft yolks.
To Drive Axle U Joint Diagnosis
