Need Help
Old Nov 20, 2005 | 08:21 AM
Blaster's Avatar
Blaster
4th Gear
Default Need Help
Well its time to put the new edelbrock intake on the vette I cant find the book on this anyware. Does anybody remember the tourqe value and the pateren to tighten this down with?
Any help would be appreciated.
Old Nov 20, 2005 | 10:39 AM
Retro78's Avatar
Retro78
My edelbrock had this with the paperwork that came with the intake. Suggest you try their web site.
Old Nov 20, 2005 | 05:42 PM
guppie's Avatar
guppie
St. Jude Donor '08
Just put mine on about a week or so ago.
25lb torque
12/11 4/1 5/6
=================distributor
10/9 3/2 7/8
Hope the pattern makes sense
Old Nov 21, 2005 | 12:11 AM
Blaster's Avatar
Blaster
4th Gear
Did any one use any RTV sealent or silicone ????????
Old Nov 21, 2005 | 06:29 AM
guppie's Avatar
guppie
St. Jude Donor '08
Edlebrock said to use it around the water ports, I I used Aviation permatex (available at Napa and such)between the head and gasket then RTV around the waterports between the gasket and manifold
I almost forgot, they recommened using high temp RTV instead of the short gaskets front and back, said lay about a 1/4" bead.
To Need Help
