Exhaust Pipe Question
Old Nov 22, 2005 | 10:42 AM
theandies's Avatar
theandies
Default Exhaust Pipe Question
What is the best method of separating the forward exhaust pipes from the rear pipes on under car exhaust? I don't want to destroy the pipes so is an air hammer with a blunt tip too aggressive?
I am about to remove my transmission and want to get the exhaust out of my way. I am sure I can do it with it just disconnected but if I separate the pipes that go through the cross member then I'll have a lot more room.
Suggestion or tried and true methods please!
Old Nov 22, 2005 | 11:26 AM
Gordonm's Avatar
Gordonm
Heat Heat and more Heat. Once you get it real hot glowing if needed you will just have to wiggle and work to get them apart. I put anti seize on the pipes so they come apart easier later. I have had mine apart many times now.
Old Nov 22, 2005 | 02:42 PM
TopGunn's Avatar
TopGunn
I agree, I did mine with a friend. One guy heats the joint while the other twists the muffler/tailpipe assembly and pulls at the same time. They came right apart, then removed the tailpipe muffler assembly. Mine were rusted together pretty good too. We used a pipe spreader to expand the tailpipe and put some antiseize on the pipe when we put it back together.
Bill
Old Nov 22, 2005 | 03:59 PM
theandies's Avatar
theandies
Thanks guys! The funny thing is I didn't even think of using my torch. It makes sense though.
To Exhaust Pipe Question
