Engine Knocking Noise
Old Dec 2, 2005 | 09:01 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
took the old pump off....the arm of the pump was loose and could be moved from side to side...thus the knocking noise. Thanks guys for all your help! Replaced the broken stock pump with a chrome Holley 80gph high performance fuel pump.....
Old Dec 2, 2005 | 09:06 PM
vetteguy75's Avatar
vetteguy75
Old Dec 3, 2005 | 07:42 AM
marshrat99's Avatar
marshrat99
Danke ! Great that you've found the problem. Those little things, while simple to fix, are hard to diagnosis sometimes.
Old Dec 3, 2005 | 07:50 AM
comp's Avatar
comp
