1980 differential steel sleeves
Old Nov 22, 2005 | 10:20 PM
smiley100's Avatar
smiley100
6th Gear
Default 1980 differential steel sleeves
I need your help! I have a 1980 corvette and i have the rear differential out. I'm almost ready to put it back in. I have one question i need answered. I saw somewhere that if you install poly bushings in it for the carrier, you must knock out the steel sleeves that were in it from the factory. Is this right?
Old Nov 23, 2005 | 07:03 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
...moved to C3 Tech...
Old Nov 23, 2005 | 10:52 AM
tracdogg2's Avatar
tracdogg2
Yes.
Old Nov 23, 2005 | 09:42 PM
smiley100's Avatar
smiley100
6th Gear
Thanks!
To 1980 differential steel sleeves
