Help needed with steering wheel removal
Old Nov 25, 2005 | 08:06 AM
USARMYTTT's Avatar
USARMYTTT
Default Help needed with steering wheel removal
What's going on yall? I hang in the C5 area but I have a friend who needs to remove his steering wheel on his 1993 to repair the high beams...can anyone here help him out with a tutorial?
Thanks in advance.
Todd
Old Nov 25, 2005 | 10:41 AM
GaryS's Avatar
GaryS
Originally Posted by USARMYTTT
What's going on yall? I hang in the C5 area but I have a friend who needs to remove his steering wheel to repair the high beams...can anyone here help him out with a tutorial?
Thanks in advance.
Todd
If you go to your GM Service Manual for your year, there is a photo (at least there is one for 72) on how to do this.
Essentially,
remove battery cable because you are dealing with the horn contacts
pull straight up on the horn button to remove it
remove the large nut holding the steering wheel on
using a steering wheel puller (available cheaply or even borrowed from Auto Zone and Advance Auto) pull the steering wheel.
As a side note, make sure that the wheels are straight and the steering wheel is centered before you do this. If you don't have a GM Service Manual, you can purchase one from many places including www.ncrs.org. Click on the store logo.
Gary
Old Nov 25, 2005 | 11:31 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Uh -- what year Vette are you asking about?
Old Nov 25, 2005 | 01:09 PM
USARMYTTT's Avatar
USARMYTTT
added the year...duhhhhhhh. It is a 1993.
EDIT... I meant this..."dhhhhhhh" to MYSELF for not adding the year. It was NOT meant at anyone else.
Old Nov 25, 2005 | 01:41 PM
BUGGSY1970's Avatar
BUGGSY1970
That was a pretty rude reply. The reason it was asked was that this is the C3 section which covers Vette's built from 1968-1982. The question was asked in case there was a question with your typing skills. Evidently the problem is not physical.
Old Nov 25, 2005 | 01:52 PM
1Z87L8's Avatar
1Z87L8
i believe he was saying DUHHHH to himself for not putting the year in his original post as he has edited it.
Old Nov 25, 2005 | 04:21 PM
USARMYTTT's Avatar
USARMYTTT
Wow...Buggsy1970...take a chill pill!!!!
1Z87L8 Quote:
You my friend were right on the money...I WAS SAYIN DUHHHH to MYSELF!!!!! Whew!!!!
Old Nov 25, 2005 | 04:40 PM
62fuelie's Avatar
62fuelie
If it's a 93, I would presume it has at least a driver's side airbag? If so, get a service manual specifically for that year car and follow the instructions VERY carefully. An accidental airbag deployment is a real bummer at best.
Old Nov 25, 2005 | 10:51 PM
mstock's Avatar
mstock
Default If I recall...
On the C4, when you go to fix the high-beam switch, sh...stuff...falls out(a spring and some other pieces I don't remember). I was going to fix it on my C4, but after all I read...I decided it was fine just the way it was . As I recall, part of the falling pieces were from the high bean, the other were from the turn siganls. Have fun!
To Help needed with steering wheel removal
