Source for 3" SS Mandrel Bends?
Old Nov 25, 2005 | 11:12 PM
75 Hot One's Avatar
75 Hot One
Default Source for 3" SS Mandrel Bends?
Does anyone know who makes 3" diameter 409SS mandrel bends? I've checked around on the internet and it seems no one makes these.
Old Nov 25, 2005 | 11:24 PM
ZL1powr's Avatar
ZL1powr
Jeggs has them. I used them to build the exhaust system for my 65. They may be 300 series SS instead od 400 series though?
Old Nov 25, 2005 | 11:41 PM
LS-Five's Avatar
LS-Five
East bound and down...
You might also give Stainless Works a try. I'm sure they can get you anything you need. Jeg's may be cheaper though...
Old Nov 26, 2005 | 12:34 PM
75 Hot One's Avatar
75 Hot One
304SS and carbon steel mandrel bends are fairly easy to find. It seems that 409 is harder to bend and/or there's little demand for it so 409SS is very hard to find. Stainless Works handles only 304SS but I'll give them a call.
Old Nov 26, 2005 | 12:36 PM
comp's Avatar
comp
is 409 the type that doesn't polish well ???
Old Nov 26, 2005 | 01:04 PM
75 Hot One's Avatar
75 Hot One
I've never tried to polish 409SS but I'd say it won't shine like 304SS. The mirror-finish parts that are around are 304SS. 409SS is the material used by the OEM's. It's not as corrosion resistant as 304 and will discolour but it has a lower coefficient of thermal expansion and is less prone to cracking. I'm not concerned about appearance, in fact, I don't want any shiny stuff under the car.
Old Nov 26, 2005 | 01:26 PM
comp's Avatar
comp
thats what i want to
Old Nov 26, 2005 | 07:48 PM
norvalwilhelm's Avatar
norvalwilhelm
409 stainless is a very poor quality stainless. It is the normal automotive industy standard between the engine and the catalytic converter. It is used in trail pipes on trucks . If is often aluminized to give it a nice finish. I got 5 3 inch truck tail pipes and used them as my bends and used 304 stainless for piping.
No way 409 stainless can be polished to look like 304.
Old Nov 27, 2005 | 12:10 AM
Maymyvetteliveforevr's Avatar
304 stainless is what they use in commercial kitchen use. It doesn't rust and is non magnetic. As for harder to bend, that would also depend on the gauge.
Old Nov 27, 2005 | 01:21 AM
simivette's Avatar
simivette
Burns Stainless has the largest selection of bends, collectors, transitions, etc. Expect to pay high dollar. If your parts are cracking with 304, they are going to crack with 409. You may need to engineer your design to accomodate expansion. Also note that stainless should be " back gassed " while welding, this is critical. Burns sells a material called "Solar Flux" which can be used as an alternative to " Back Gassing ".
To Source for 3" SS Mandrel Bends?
