Best Cam for 427 small block?
Old Nov 26, 2005 | 11:29 AM
KJL's Avatar
KJL
Default Best Cam for 427 small block?
You can see from my sig that my current cam is a XE-282-HR. The specs @ .05 are 230/236 and .510/.520. I am installing a set of AFR 210's that have been Competition ported. They have better flow numbers than the Dart 215's. I have a recommendation from Crane and Comp Cam but I would like to get some forum input as well. The car is a weekend driver that will see some strip time.
Old Nov 26, 2005 | 11:46 AM
Solid LT1's Avatar
Solid LT1
427 cu/in? A BIG ONE! I would say you would want a XR294H or XR300H catalog grind from Comp Cams.
Old Nov 26, 2005 | 09:05 PM
vetteaddic's Avatar
vetteaddic
Im running a Comp cams solid roller in my 427sb with dart pro 1 230s
Lift .616/.622
@.50 248/254
Lsa 112
small base circle
theirs a slight lope to it , not what im use too,and the vacumn is good too .
I might try something a little more radical later,other than that the engine just gets it.
If you want a cam that has good idle and vac this is the one.
Old Nov 26, 2005 | 09:53 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I have a 236 degree @.050, 108lsa .507 lift cam in my 434.
Puts me at about 12.90 in the 1/4. Prolly needs tuning for another 2-3 tenths...
Vetteaddic;
Do you have track times with that engine?
Old Nov 26, 2005 | 10:08 PM
vetteaddic's Avatar
vetteaddic
No track time yet or dyno,Id like to find out myself what hp is ,Im afraid of going to the track and leaving my rearend there,
I have done nothing to the rearend except carbon fiber halfshafts ,offset t/a .
My next motor will be a 434 ,is that a 4.155 bore x4.00,I wonder if i can get a bigger bore,4.165 or 4.185
Old Nov 26, 2005 | 11:58 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Put a solid roller in there, I have the Comp Cams XR280R in my 406ci and I love it, specs are in my sig. It shakes real nice at idle, you could go 1 or 2 sizes bigger
Old Nov 27, 2005 | 10:01 AM
79VetteMike's Avatar
79VetteMike
I'd say you need a bigger cam also. I'm building a 396 small block with a Howard's roller cam-236/242 duration; 576 lift; 112lsa.
Old Nov 27, 2005 | 11:05 AM
KJL's Avatar
KJL
Thanks for the input!! The folks at Crane and Comp Cams recommended the folllowing hydrolic rollers:
240/248 @ .05 .558/.558 110 LSA & 105 intake centerline
248/254 @ .05 .599/.619 110 LSA
What would be the benfit of going with solid rollers instead of hydrolic?
I have read that solid rollers have lubrication problems when used in street applications.
To Best Cam for 427 small block?
