progress front clip off
Old Nov 26, 2005 | 10:33 PM
gator79's Avatar
gator79
Default progress front clip off
well this was much easier than I thought it would be. took me 6 hours by myself, just had my sons help me lift it off. I am replacing with a one piece, this one had tons of bubba fiberglass repair done to it and would have taken forever to straighten out.
Old Nov 27, 2005 | 09:30 AM
Corvettj's Avatar
Corvettj
Default great job
So, let me know how the front clip replacement goes, I have one ready to go, but have not gotten up the talent to put it on
CJ
Old Nov 27, 2005 | 09:44 AM
dennis's Avatar
dennis
nice job. I have a doner front clip to remove and then install on my 70. Did you get yours off without damaging it? I see the rear bond at the door is easy enough to get to, but how did you get to that one forward of the door at the firewall?
Old Nov 27, 2005 | 10:31 AM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
I like the oil drip mat.
I agree, don't forget to post installation thoughts and pics when you get to that point.
Old Nov 27, 2005 | 10:35 AM
Twin_Turbo's Avatar
Twin_Turbo
Check the birdcage and frame near the front body mount, there's that foam block wedged between frame and birdcage to keep crap out but it's excellent at trapping moisture, a lot of cars have rotted there...so might want to check it out now that you can. You can see that the area is fairly rusty already, hopefully only surface rust.
Old Nov 27, 2005 | 01:14 PM
gator79's Avatar
gator79
no damage getting it off, I just used a wide wood chisel and wedged it between the between the panels and worked slowley. i removed the egg crate grills to gain access.
74 VERT, oil drip mat courtsey of my employer. old showroom banners ar good for something
To progress front clip off
