weather stripping question
Old Nov 27, 2005 | 08:12 PM
TRAVIS74's Avatar
TRAVIS74
Default weather stripping question
I just installed new weather stripping on my freshly painted doors and have to slam them pretty hard to get them to shut. Is this common because of the newness of the weather stripping or have I done something wrong? Thanks for any help.
Old Nov 28, 2005 | 12:19 PM
Wuttin's Avatar
Wuttin
I replaced the stripping on my T-tops a while back and had the same problem..I couldn't get the top in far enough for the pin to able to lock. Once it conformed to it's new found shape it was fine. Beware though, the stripping will adapt to the new shape and stay that way...if it's twisted or misaligned while closing the doors it's likely it will be that way for good.
Old Nov 28, 2005 | 12:50 PM
alanbl's Avatar
alanbl
Originally Posted by Wuttin
I replaced the stripping on my T-tops a while back.....
So, how has the new weatherstripping been working? My panels start leaking in a heavy rain and I'm planning the same repair. Where did you get your replacement pieces?
Old Nov 28, 2005 | 08:58 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
From what I've read on the Forum it takes a while for the rubber to form and the doors will close easier over time. What weather stripping did you go with? Does it seem like good quality? I'm looking to do the same.
Old Nov 29, 2005 | 07:42 AM
kb2fzq's Avatar
kb2fzq
Gotta do the seals on the T-tops on my 76 as well...does anyone know if the seals are glued on or if it rides in a track of some sort...Year-One sells a weatherstripping removal spray and just curious what that would be for??
Old Nov 29, 2005 | 11:43 AM
JIMS1970VETTE's Avatar
JIMS1970VETTE
Hi, I just had my 70 vette done and they are very tight also but in time they will conform.
Old Nov 29, 2005 | 11:52 AM
Darrel1's Avatar
Darrel1
New seals need time to take a set. It will happen sooner in warmer weather. I would keep all the panels closed for a few days or maybe a week. After that you should see a difference.
Darrel
Old Nov 29, 2005 | 12:10 PM
TopGunn's Avatar
TopGunn
The seals are glued and also have plastic tabs that push into the top. Use 3M contact adhesive after cleaning all the residue off from the old ones. I didn't need the adhesive removal stuff, a little alcohol solvent used carefully removed what was left.
I bought mine from Corvette Rubber last year.
Bill
Old Nov 29, 2005 | 12:17 PM
markdtn's Avatar
markdtn
Mine are still very firm after 2 years. Doors shut good, but you have to close harder than without weatherstrip. Door panel was dragging a bit too. That makes a difference.
Old Nov 29, 2005 | 03:43 PM
Wuttin's Avatar
Wuttin
They came with the car when I bought it but I'll see if I can dig up the receipt...I know it wasn't from Eckler's or Corvette America, but a weatherstripping/trim specialty shop (A strip joint?)
I haven't had any leaks (from the tops ) since I replaced it.
Good luck
Old Nov 29, 2005 | 04:11 PM
TexasYankee's Avatar
TexasYankee
I was just shopping for T-top replacement rubber:
http://www.ecklers.com/product.asp?p...&dept%5Fid=253
I really only need the driver's side but I suppose doing both of them together would be wise.
On a scale of 1 to 10, how hard is this project? (10 being hardest).
Old Nov 29, 2005 | 04:24 PM
big_G's Avatar
big_G
Maybe a 3...pretty straight foward....
Old Nov 29, 2005 | 06:56 PM
69monzacpe's Avatar
69monzacpe
I just replaced the door and window frame gaskets, and had a problem with closing the door. I got some silicone spray and sprayed on both gasket surfaces. Doors closed great afterwards. Just keep the overspray off the paint.
Old Nov 29, 2005 | 07:48 PM
carl a's Avatar
carl a
a one i would say
Old Nov 30, 2005 | 07:58 AM
kb2fzq's Avatar
kb2fzq
Bill
OK...that's what I was looking for...and a job difficulty rating of 1 --> 3...I can do that....thanks guys
Old Nov 30, 2005 | 09:13 AM
Brandywine's Avatar
Brandywine
If all the necessary vertical and horizontal adjustments have been made to the door glass for proper fitment... Park the car in a WARM sunny place, then open the doors, roll the windows up, close the doors. If everything is sealed correctly(including the T-Tops) you should be good to go after a few days.
Old Aug 5, 2021 | 10:45 PM
Tim Reeves Sr's Avatar
Tim Reeves Sr
4th Gear
Default 1981 Corvette t-top weather stripping. I bought mine from Zip's verys good seals
Go with zips weather strip
Old Aug 7, 2021 | 04:19 PM
vettebuyer6369's Avatar
vettebuyer6369
You are answering a post from 16 years ago.
To weather stripping question
