Does no one know how to replace the window regulator gear?!
Old Nov 28, 2005 | 12:09 AM
enkeivette's Avatar
enkeivette
Default Does no one know how to replace the window regulator gear?!
I want to replace the regulator gear of my 78 drivers side power window. And I don't want to use the gear repair kit.
I've been holding off on an order for over a week now looking for an answer. What do I need to do this? Do I need a new rivet or any special tools? Has anyone else done this before?
Old Nov 28, 2005 | 12:35 AM
GDaina's Avatar
GDaina
you can use small bolts and nuts in lieu of the rivets...unless you want to use rivets, you will have to pay big bucks for a rivet gun that uses the larger rivets.
Old Nov 28, 2005 | 01:48 AM
enkeivette's Avatar
enkeivette
Thanks GDaina, and can I re-use the 'rivet' that sits in the center of the spring, holding it in place?
Old Nov 28, 2005 | 04:23 AM
Jasonty's Avatar
Jasonty
If the large spring is rusted, now might be a good time to replace it. Mine broke on me, and required me to remove the regulator assembly. Not really a PITA, but if you're already in there, might as well do it. As for the rivets, I'd use nuts and bolts as suggested above.
Old Nov 28, 2005 | 05:24 AM
enkeivette's Avatar
enkeivette
This is the 'rivet' that I was talking about. Does it need to be replaced when installing a new gear?
Old Nov 28, 2005 | 10:57 AM
danno12345's Avatar
danno12345
I would say yes, it needs replaced, since I can't think of a way to remove the rivet without killing it. On the other hand, I wasn't sure how to get the new one peened in correctly, so I didn't do anything on mine... yet.
Good luck!
Old Nov 28, 2005 | 11:01 AM
jdp6000's Avatar
jdp6000
Nah...no need to replace that part unless yours is broken. I replaced my regulator springs. You need to take the entire assembly out to do it.
Jim
Old Nov 28, 2005 | 01:04 PM
68/70Vette's Avatar
68/70Vette
The current issue of Corvette Fever (or was it last months?) has an article on how to replace/renew the regulators. Also how to change the hardware associated with the window. The article is probably available at their website. Lots of pictures.
To Does no one know how to replace the window regulator gear?!
