TH400 1 - 2 shift problem
Old Nov 29, 2005 | 07:52 PM
69monzacpe's Avatar
69monzacpe
Default TH400 1 - 2 shift problem
I'm getting a shift problem from 1st-2nd gear (upshift), more prominent after cruizing for a while when the trans is good and hot. I rebuilt the trans a few years ago, used hi-po disks and plates, stock valve body. This was the third one I rebuilt, other two never had any problems until they flat wore out.
This one sat dry for a while. Here is what I have tried so far to remedy the problem. I replaced all rubber vacuum lines to the modulator, replaced the modulator, added trans x and ran 200 miles, drained, replaced filter and refilled.
I took it to a dealership, and they said everything was fine and that the pressures looked good. Of course, as usual, it doesn't do it when you have them in the car. Plus, like I said, the longer driven, the worse it seems to be.
Sounds like a slight grind or pop when accelerating heavily. I spoke to a mechanic friend, who thought it might be the accumulator. Right now I am taking it VERY easy when driving during 1-2 shift. 2-3 shifts fine.
Any suggestions???
Old Nov 30, 2005 | 06:44 AM
gerry72's Avatar
gerry72
Sounds more like the sprag. But before you gut the thing, do a fluid (use a Dexron fluid. No "racing" type F modified fluids) and filter change to see if that improves things.
Old Nov 30, 2005 | 05:47 PM
69monzacpe's Avatar
69monzacpe
It's probably the sprag then. I already replaced the fluid and filter. If I have to pull it, I'll probably do a conversion to the 700R4.
Old Nov 30, 2005 | 06:04 PM
comp's Avatar
comp
was there anything in the pan ???
Old Dec 6, 2005 | 05:40 PM
69monzacpe's Avatar
69monzacpe
I found one small sliver of aluminum, otherwise normal black build up from clutches.
The piece of aluminum was about .125" diameter, .001" thick.
To TH400 1 - 2 shift problem
