TPI Conversion
Old Dec 6, 2005 | 10:15 PM
DR.Jay's Avatar
DR.Jay
Originally Posted by Brandywine
Jims Performance has a nice write-up on the Internet about GM TPI's, including VATS delete, fuel pumps, conversions, etc. Here is the link.
http://www.jimsperformance.com/portinj.html
Here's what he did to my ZZ4...
Thanks for the link. That Looks Really Nice.
Old Dec 8, 2005 | 07:36 AM
markdtn's Avatar
markdtn
Originally Posted by 81fastvette
Patsnitrovette - How did you mount the tpi pump? Did you just cut off the pickup tube a bit flare it and run a hose between the pump and pickup? Just trying to figure out if I can do this on my 81' pickup. Did you run High pressure rubber lines from the pickup to steel line? Appreciate the help as plumbing is the big challenge I face.
On an 81 truck, get a tank for an 87 (TBI injected) and swap the pump. LWB are harder to find than SWB for some reason. That tank was used on all gas 87s and Duallys 88-90. GM has discontinued the tank and maybe the sender by now. I ruined my sender hooking it up and it was like $250 without a pump.
Old Dec 8, 2005 | 09:14 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Here's my old motor.
Old Dec 8, 2005 | 12:26 PM
BLACKHORSEVET's Avatar
BLACKHORSEVET
Originally Posted by Mr.L
I have done several!!! Do a lot of reading. I have found the aftermarket wiring is much cleaner and easier to install. The thing to remember is that you are setting the TPI as a stand alone setup. The main problem with C3 is the gas tank. The pickup is OK for a carb but not with TPI, it will suck air at 1/4 tank. The 82's have pump in the tank but lack the baffels to stop the fuel from moving away from pump, so no help there. This also happens with outside fuel pump. If you cant live with that you have to drop the tank and pull the bladder out and modifiy it like the guys that run giggle gas do. 91 TPI should be a MAP with VAT setup. You will also need a VSS on the trans. You will need a custom chip with no VAT codes and this is where you can get rid of all the clean air stuff that the stock computer reads. Also MAP does not lend itself to a modified engines. I like MAF setup you can add some nice HP to the motor and it still runs nice. If your state requires inspections then you may have to install the clean air BS that does nothing anyway, but you will still have to get a chip without the VAT. I also like to use the TPIS runner tubes, they make up a lot of the shortfall of TPI (power dropoff after 4800 to 5000 rpm) mine reves to 5800 with no trouble.
I have been very happy with the TPI setups I have done. My gas milage has jumped way up, my 81 C3 went from 10mpg around town to 18 mpg. HWY was always great because of the 3.08 gears and the lockup 350 trans. With the TPI there is a GREAT difference in low end power which is great for around the town driving.
If a map system doesn't lend itself to modified engines,couldn't you make up for that shortfall with a custom chip made specifically for the motor you want to build up and modify?
Old Dec 8, 2005 | 12:44 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Yes, but it is a pain. You have to remove the chip and hopefully the person burning it will understand the information you give him over the phone. It took me 4 chips before mine would even idle and I had a small cam.
Old Dec 9, 2005 | 01:34 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Just burn your own: www.diy-efi.org/gmecm
Old Dec 9, 2005 | 08:12 AM
PatsLs1vette's Avatar
PatsLs1vette
I too took a while to get my chip right sending it back and forth,but the latest time worked great,if you can do it yourself do it.
Old Dec 9, 2005 | 12:57 PM
Contrail's Avatar
Contrail
Prominator
www.speedtronics.net
Old Dec 11, 2005 | 10:35 PM
DR.Jay's Avatar
DR.Jay
Default Update apology
I wish to appologize to all of you. I was i think mis-informed. I saw the donor camaro yesterday for the first time. I ran the vin numbers, and the vin code reads that it is an '84 not a '91 as I had orginally posted.
Something is not right though. It has centerbolt valve covers (i think should be '87, and newer) and the small distributer,mass air sensor, no vats, but it has the '84 style belts. I'm confused and I will have to do more reserch.
It was an auction car that was given to me buy a guy I do work for. He got it at the local dealers auction for pocket change It had been sitting on the auction lot for 5 years.
The 10th vin digit is a (E)
The 8th vin digit is a (G)
The engine trim code says it is a (L69) TPI
DR. Jay
Old Dec 12, 2005 | 01:48 AM
DonBecker's Avatar
DonBecker
I'm trying to wrap up my TPI conversion.
I have a 76 L-48, and put a 86 'Vette TPI on it.
I'm using a custom EFI controller: www.megasquirt.info
Getting all the parts and getting it installed was the hard part (or so I thought). The rough part for me has been learning how all the sensor readings come together to control how the engine runs.
In short, there are two ways to do this. Or three.
1. Stock computer and chip. This is the easiest, as once it's installed, it should just work, right? Well yes and no. Odds are, the settings on the chip are meant for the engine that you pulled it off of. So it won't be exact. Some folks have got it to run great, and I've also heard alot of "forget the TPI, it doesn't work, run carbs, they make power..." which is probably from others trying the stock chip.
2. Stock computer, modified chip. This has a fair chance of running really good, but you are going to have to do your homework about how it all works. It's kinda harder than #3 because you are actually tied down to the way the OEM did the controller, they all have their own little nuances and I doubt you can change it much.
3. Custom controller. This is the path I took. My car runs, I drive it everyday. I still haven't seen a gas milage improvement yet, but it is all about me learning how to tune the car. Basically, it's very similar to the stock computer/modified chip that I described above, however, the controller is general enough that you are learning what all the numbers do as you go along. If it doesn't run well, it's not EFI, not TPI, and not the controller, it's your tuning skills (I mean mine) that suck.
What I would have to boil this down to is, if you want to convert over to fuel injection, you can either learn alot about how it works or try to pay someone else to do it all for you.
As for your initial questions about fuel, I am running a Holley pump (really a Walbro) on top of the pass. side rail beside the gas tank. Works great.
As for problems past 1/4 tank, well, you really shouldn't run under 1/4 tank as the pump is cooled by the fuel it is pumping. If you only have a 1/4 tank, that fuel will be hotter than it would be at a 1/2 tank, and thus, the pump will run hotter and possibly fail earlier. Just a thought.
Post if you need any other info.
Old Dec 12, 2005 | 06:34 AM
PatsLs1vette
dr jay even though the belts are the older style it might be a 86-87 setup,my 87 trans am setup came with v belts and a small serpentine flat belt on the alternator,they didnt go to 1 serpentine belt till 88 i believe in the camaros and t/a's.
Old Dec 12, 2005 | 05:09 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Yeah, you have to do your homework...but everything is on the chip. Displacement, fuel curves, fuel mixture, you name it, it's there. You can change it to do whatever you want. It's like the human body - little brain tells the rest what to do.
Old Dec 13, 2005 | 08:40 PM
  #33
DR.Jay's Avatar
DR.Jay
I just checked out the "Mega Squirt" web site. Lots of reading to do their. It appears to be a great DIY set up for fuel injection. It has great tuning capabilities, but it seems to eliminate many of the stock sensors, and Ecu functions (including the invasive emissions junk. )
I still have to do more research on the donor car though. I have only seen it at night, with a cheap flashlite. It all appears to be there, and some of the things that don't appear to be right can easily be explained, like the center bolt valve covers (engine swap with late model engine). I may get lucky and have a good running motor. The oil is really clean (for sitting for 5yrs), and the coolant is up.
I'll keep posting updates as I go along.
Thanks again.
DR. Jay
Old Dec 13, 2005 | 10:24 PM
  #34
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Those stock sensors are there for a reason - and you can turn off any of the emissions stuff you want during the recoding.
Old Dec 14, 2005 | 07:49 AM
  #35
markdtn's Avatar
markdtn
You need most of the sensors to make it work right. You can eliminate VATS, canister purge (although I would keep it), and EGR but that's about it. You need the rest including VSS to make it work best.
