alternator - any special issues
Old Dec 5, 2005 | 08:26 AM
75coug's Avatar
75coug
Default alternator - any special issues
I think that the alternator in my 1981 C3 died last night, and I plan to have the car towed to a shop today for examination. Are there any special issues with regard to this alternator of which I should be aware?
Old Dec 5, 2005 | 08:35 AM
texaswilkins's Avatar
texaswilkins
Don't have it towed just for the alternator. The alternator is an easy job (2 bolts) and I'll come over to help if you want me to.
Bill
Old Dec 5, 2005 | 08:44 AM
75coug's Avatar
75coug
Bill
Wow, thanks for the fast response. It's nice to see that there is another McKinney resident on the board.
As you can tell, I am as mechanically inept as there is. I therefore appreciate the offer. If I go to one of the local parts stores, are they likely to have the alternator that I need?
If you really don't mind helping me with this task, shoot me a PM or e-mail me. Thanks!
Old Dec 5, 2005 | 09:41 AM
Gordonm's Avatar
Gordonm
They should have one or be able to get one pretty quickly. It is nothing special or rare. Easy job should be able to switch it out in about 1/2 hour.
Old Dec 5, 2005 | 06:35 PM
guppie's Avatar
guppie
St. Jude Donor '08
Bill
That's whatI like about this forum, People like you everywhere here.
Old Dec 5, 2005 | 09:00 PM
David Ey's Avatar
David Ey
Me Too.....C3 folks are the greatest
Old Dec 5, 2005 | 09:13 PM
DR.Jay's Avatar
DR.Jay
Bill
I'd do the same if I was still working in the area, But I think Bill is a whole lot closer.
Good luck, let us all know how it goes.
DR. Jay
Old Dec 5, 2005 | 09:29 PM
GaryS's Avatar
GaryS
Bill
There is a local shop in the Pittsburgh area that you can walk, drive, or scooter your alternator to. With a set of multiple connectors he can hook up any brand of alternator to his testor and tell you what is/is not going on there. You should be able to find one in your yellow pages.
Gary
Old Dec 5, 2005 | 11:04 PM
75coug's Avatar
75coug
Thanks for the support, folks. This is such a great board. Bill and I are IMing, and it looks like we'll have things worked out soon.
Old Dec 6, 2005 | 01:06 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I 'upgradded' my alternator on my 1980. I got one from a 1986 Corvette. It puts out about 100 amp instead of the stock 63 amp. This is good if you have extra radio equipment or electric radiator fans. All I had to do was pull the pulley from the original alt and put it on the new 1986 alt.
There are 2 bolts that hold the alternator in. Then you have 1 bolt on the back for the ground wires, 1 nut that holds the positive wires and 1 two wire connector on the top. Make sure to disconnect the ground from the battery before you start anywork. Get a Haynes manual and they should have the removal / install instructions in there.
Old Dec 6, 2005 | 01:23 AM
comp's Avatar
comp
Old Dec 6, 2005 | 02:02 AM
Retro78's Avatar
Retro78
Originally Posted by comp
Hey comp... this is getting pretty old. 28,156 posts of this amounts to nothing. It does not help anyone. Why don't you ever say something?
Old Dec 6, 2005 | 07:54 AM
norvalwilhelm's Avatar
norvalwilhelm
Guys that just drop in to run their count up and say nothing tick me off too
That said I picked up a truck 150 amp alternator and had no trouble bolting it in. I made the mistake of going for the single wire and it doesn't work that well. If you draw power from under the dash the single wire alternators can't compensate for the added draw and increase their output. They sense output from the alternator itself and any draw further down the road doesn't alow the alternator to increase it's output.
Old Dec 6, 2005 | 08:23 AM
gerry72's Avatar
gerry72
That's not fair. He contributes far more than
He weighs in frequently with and
Now if those three don't advance anyone's understanding of a complex techical issue, then I don't know what does.
Old Dec 6, 2005 | 08:51 AM
Milest's Avatar
Milest
An added thought.... If the alternator is bad then there is a good chance that the battery is dead as well. Bring a charger or some other means to jump it. Good luck.
Old Dec 6, 2005 | 09:07 AM
rick76's Avatar
rick76
7th Gear
Default Old Trick from an old man
A quick and cheap check for an alternator is to take a long steel screwdriver and hold it loosly near the alternaor while the engine is running. If the screwdriver is attracted magnetically to the alternator then you probably have another problem like the battery.
Old Dec 6, 2005 | 11:47 PM
glen242's Avatar
glen242
Post *****. Probably has low self-esteem. Needs to have big post numbers to feel good. Probably does not own a 'vette. Needs to post 35 times a day to feel worthwhile. Mech. ocupation is probably bogus, as he doesn't post mechanical help.
Why doesn't a moderator or someone warn these guys, that if they keep posting BS and those smilies in a tech or general forum instead of the OT forum, they will be booted out. Takes up Forum bandwidth, and I hate seeing all those smilies as the only thing in a message.
To alternator - any special issues
Old Dec 7, 2005 | 07:30 AM
75coug's Avatar
75coug
texaswilkins was of great assistance to me, and my '81 now has a new alternator and is up and running once again . . . just in time to get it indoors before the bad weather hits. Thanks to Bill and the board in general for the help. It was greatly appreciated.
Old Dec 7, 2005 | 07:42 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
make sure that the pulley is the same size! when i swapped mine out, i had to change the pulley from the old one over to the new one.
Old Dec 7, 2005 | 08:13 AM
texaswilkins
This board has been real good to me and if I can return the favor by helping somebody out then that's the least I can do.
Bill
