Is it triming the end of my fiberglass spring for wheel clearance? Or is it triming the mounting pad where the spring mounts to the rear end? It seems that if the pad is trimed, maybe I'll have a better chance of tucking the spring end inside my 18" wheels while keeping a nice low ride height? I've seen the spring pad trim mentioned several times, but I don't know exactly what it is.
Bee Jay
The spring pad is the cushion between the spring and the diff cover. So trimming this will lower the car some without the typical bolt lowering of the outer spring bolts.
I have been thinking about doing this also. It is just a piece of rubber or hard plastic. I can't remember which. It should just be cutting or grinding it down. I have a PM into someone here who has done it to see how he did it.
Excellent post. Thanks. I'm gonna remove my rubber pad entirely, and replace it with a 1/4" phenolic spacer. Now if I can only find out how to bend my sway bar inward slightly.
Bee Jay
I just pulled my TRW composite spring. There is a metal plate about 1/4", and a phenolic plate about 1/4" between the spring and rear end. I simply removed them. No cutting except I had to trim the round rubber thingie that goes up into the hole on the rear end. It moved my spring about 1/2 up into the wheel. I will replace the phenolic spacer, but leave the metal one out.
Bee Jay
Food for thought... Do we need to worry about added heat transfer from the diff?? Fiberglass being much more susseptable to failure from the heat than metal.
TJ
There is still an insulater there. I have IR gunned the temp on my diff and it is usually only about 140 after a run on the road. Maybe if you are road racing it might get the temps up but I don't think it would be enough to do any harm to the spring.
140 degrees? That's all? Heck, I may not even put the phenolic spacer back. The closer to the rear end, the farther from the exhaust. Hey,
Gordo, once again you come thru with some valuable info. Thanks.
Got your wheels yet. All I need now is my adapter/spacers.
Bee Jay
Gordonm kinda funny you are impatient as I am impatient as well and they are not even going to be my wheels lol. Can not wait for the great info you will give with this problem.
You guys will be the first to know when they come!
