non starting engine
Old Dec 6, 2005 | 08:08 PM
Jclgodale3's Avatar
Jclgodale3
Default non starting engine
same engine, different carb. Replaced the Quadrajet with a Holley 650. When first installed, it started and ran for a couple seconds. Finished hooking everything else up. Getting spark and carb is getting gas. Absolutely...will not fire! Suggestions or help?
Old Dec 6, 2005 | 08:10 PM
enkeivette's Avatar
enkeivette
Is your choke working? You'd be surprised how much of a difference that will make. If not, close it manually.
Old Dec 6, 2005 | 08:13 PM
Jclgodale3's Avatar
Jclgodale3
it's working...it's electric and is closed all the way...
Old Dec 6, 2005 | 08:40 PM
kdf1986's Avatar
kdf1986
You wrote that it ran, then you finished hooking every thing else up.
Does that mean that the motor ran, then you turned it off to connect some other stuff up, now it wont start anymore?
What was it that you connected? Anything electrical?
kdf
Old Dec 6, 2005 | 09:49 PM
Jclgodale3's Avatar
Jclgodale3
kdf
it started for a few seconds. Stopped to hook up PVC hose, Power brake hose. Did not hook up or unhook any wiring. It's getting spark and Fuel
Old Dec 6, 2005 | 10:41 PM
Jclgodale3's Avatar
Jclgodale3
it was flooded...vettepilot68 got me going. Good to have a fellow member and good friend 3 houses down
Old Dec 8, 2005 | 11:57 AM
kdf1986's Avatar
kdf1986
Thanks for posting the fix to your problem.
I think that this is one area that we can all help out on. When we ask for help to our questions, we get many replies. It would be good to hear what the fix or solution to the problem was.
In your case it may have been simple. The carb was flooded. Case closed.
Thanks for the update.
kdf
To non starting engine
