Just spotted a tiny puddle under the driver side, upon investigation, noticed the bottom of the tank dinged, just got the car bit over a month ago, and that seems to be where the leak is coming from. Anyone recommend a sealant for a temporary fix 'til the money tree blooms??? Used to use 'Bars leak' long time ago, was one of the best, anything better out there now? Thanks,
Randy
I use the "original" Bars Leak..try a 5 ounce bottle first...be sure to put directly into radiator,not the puke tank.....
Rich
If driver's side, also worth checking the upper radiator hose connection. Mine tends to 'form a leak' there if the car sits too long (deposits that accumulate between hose and radiator neck). Usually, can remove the hose, clean connection and adjust/re-tighten to resolve this upper-hose leak.
i understand the money problem, but do it right the first time. you might find yourself with a overheat situation and that can turn into headgaskets real fast. whats it gonna cost you, 35 bucks to get a rad shop to solder the hole? come on dude!
i feel ya wit the cash flow shortage. when i nuticed my radiator leaking i fortunately had the cash to just put a new one in since the shop i went to to price a recore was almost as much as a new brand one... problem solved and car runs much cooler with the freeflow of coolant
Those dang sealers are a double edged sword, often causing as many problems as they solve. I know it's a pain, but pulling and fixing it now is the right move. Be real cheap if you can get it out yourself, although it's a pain to pull, especially if you have A/C.
Mine started small but got worse quickly, and I considered a "stop leak" additive. Following other's advice I got a new copper/brass radiator (only 12 lbs. heavier than the old aluminum one) and it's been running cool ever since.
if its copper take it out and clean it good then get a fine torch and solder it. if you can get a small piece of copper and solder it over the hole.. the trick is it must be clean.. if its alum they have a alum stick thats easy to use.just melt it over the hole
I ran the stop-leak in mine for 10 years with no problems. Just take the fluid out every spring or so and flush the system. I used the little tube of aluma-seal or what ever it's called. Don't put in more than the instructions indicate. To do so is why everyone gets other stuff plugged...
Keep filling it until you can fix it right (unless it's leaking too much) those sealers work but are not discriminating in what they clog up
I have used this "fix" in the past and have ended up replacing cores and radiator just the same resulting in mucho more $$$$$
Just wait and do it right...replace it or bring it to a reputable radiator repair shop...you save in the long run and probably run cooler.
I totally agree. Thats what it will cost to have it fixed. You remove and reinstall.
