My block cracked
Old Dec 9, 2005 | 06:08 PM
79vetter's Avatar
79vetter
Default My block cracked
Can a block be repaired if it has a crack. It got cold here and I only had water in it. There is about a 3 inch crack in the block under the head on one side- the side I didn't let the water out of.
Old Dec 9, 2005 | 06:09 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Short answer: yes.
Long answer: unless it's something rare, don't bother. Get a new block...and run a 50/50 distilled water/antifreeze mix year round.
Old Dec 9, 2005 | 06:13 PM
big_G's Avatar
big_G
Originally Posted by I'm Batman
Short answer: yes.
and it will probably have another crack somewhere you can't see....
Old Dec 9, 2005 | 06:45 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you need to pull the intake manifold and see how many cracks are in the oil valley.....On my cracked block there were three times as many cracks there as what was visible on the outside.
Old Dec 9, 2005 | 07:02 PM
Twin_Turbo's Avatar
Twin_Turbo
it's junk..even if you inspect it you won't be able to see most of the cracking.
Old Dec 9, 2005 | 07:06 PM
groovyjay's Avatar
groovyjay
Old Dec 9, 2005 | 07:10 PM
gator79's Avatar
gator79
damn, it got that cold in Texas?
Old Dec 9, 2005 | 07:15 PM
Maymyvetteliveforevr's Avatar
I'm surprised it didn't pop one of the frost plugs first.
Old Dec 9, 2005 | 07:30 PM
chris75stingray's Avatar
chris75stingray
yeah really, isn't that what they're for?
Old Dec 9, 2005 | 07:34 PM
MikeC's Avatar
MikeC
NO. They are not actually frost plugs. The holes are required during the casting process in order to keep the sand cores for the water jacket located correctly. The plugs are merely there to keep water in the water jacket not pop when the block freezes.
Sorry about your luck but if its cracked in one place there will be more, find a new block. Remember to run antifreeze or store in a climate controlled garage.
Old Dec 9, 2005 | 08:29 PM
tigers123's Avatar
tigers123
Default never water
Anti freeze should always be run in a 50/50 mix for keeping you from overheating as well in the summertime. The boiling point of water mixed with anti freeze is higher. Look at your antifreeze charts for the facts.
Old Dec 9, 2005 | 10:46 PM
evalu8r's Avatar
evalu8r
How come the blocks always crack but the thin copper radiators don't?
Old Dec 10, 2005 | 01:22 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There is room in the top of a radiator for expansion. if you have air pockets in a block, you're asking for trouble - and I have seen frozen/broken radiators.
Old Dec 10, 2005 | 02:12 AM
Z-man's Avatar
Z-man
The copper will bend to expand, the cast iron just busts...
Old Dec 10, 2005 | 02:37 AM
Twin_Turbo's Avatar
Twin_Turbo
freeze plugs...the word is misleading, a better name is core plug.
Old Dec 10, 2005 | 07:56 AM
kb2fzq's Avatar
kb2fzq
That was my first thought...I'd junk it and get a new crate-er..you'll never find all the cracks if it's that bad..in New York we use "anti-freeze"...I know, quite the concept...UH?
Old Dec 10, 2005 | 09:09 AM
comp's Avatar
comp
Short answer: yes.
you need to drive it now ????
To My block cracked
Old Dec 10, 2005 | 10:23 AM
moosie982's Avatar
moosie982
Just wondering how they ever got to be known as "freeze plugs", maybe bubba got lucky one winter and one pushed out when his block froze and he then named 'em freeze plugs,,, any thoughts? Peace,,,Moosie
Old Dec 10, 2005 | 10:27 AM
comp's Avatar
comp
Old Dec 10, 2005 | 03:30 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
WOW, thats gotta suck. I would just get another block.
