Here are some dyno results of my 388 stroker built this year.
I am asking for your 2cents/comments, as I wasnt impressed with the HP. And while torque is high, it starts off at 2750 and goes down from there (and I have a 3500 stall).
Doesn't look like you are getting any use of your torque past your launch, though your 60' time is excellent. Looks like it is hooking up good. Your HP curve is a liitle flat. Are you shifting at 5750? The 1/8th and 1/4 times seems a little out of sync. Other than that, good numbers.
I read a post somewhere about how the dyno tends to understate the HP and torque ratings when there is a big stall converter, because the dyno doesnt provide enough resistance for it to work properly. Does anyone know anything about that? I dont know if its true or not.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by Highhat
Yes, Mustang Chassis Dyno
Motor specs:
388 stroker 10.25cr
Sportsman II heads, 2.055/1.625 valves; ported
Victor Jr, intake tall, plus 1in supersucker spacer
Holley HP 750
Comp Cam XS290 solid tappet (252/260 @ .050; 290/298 gross)
Hooker comp headers
3.7 rear; TH400 3500 stall
With that cam I would expect the HP to be slightly higher than the torque,
That does not mean the HP would be higher than the 451, the torque would come down alot and the HP should come up.
Somthing is wrong here, plugging up that motor, what mufflers do you have ?
Highhat, your dyno info may seem off because of your 3500 rpm converter.....torque converters multiply launch TQ by approx. 2.5 times or so (depending on converter) and this happens at stall speed or flash stall on the dyno. Then it gradually drops as RPM increases. Though these are true TQ readings, this is not necessarily what your engine numbers would be on an engine dyno as far as correct RPM for max TQ....(it would be at a higher RPM, perhaps 4200 or so). This phenomenon happened to me when I changed from a 2200 rpm to a 3000 rpm (4000 flash stall) converter. This changed my peak rpm readings from 4600 rpm to 3200 rpm (same motor, same rear gear). The dyno loads your car differently than actual road driving (though I heard Mustang dynos come close). It's like going slightly uphill, adding even more stall to the converter! Take note of your car in "real world" driving, and compare differences you make in components or tuning. I use the dyno as a tuning aid to measuring small changes (new carb or intake evaluation, etc.).......also, use the same dyno each time, for accurate comparisons. All are not calibrated the same.
I hate Mustang dyno's. #1 if you are execting what your friends got or others tell you they got on a Dynojet you'll be disappointed: 15% lower on Mustang just due to the type it is. #2 the way Mustang works, using torque not rotational inertia, may have an impact on numbers in conjuncction with your high stall. Someone chime in on #2 that knows what they're tlaking about. I just write this $hit
I had always dynoed my car on the same DynoJet dyno with good and consistant results. My latest results were 373 RWHP AND 452 TQ. A new Mustang dyno openned in town, closer to my house (50 miles closer than my drive to the DynoJet), so I gave it a try.......BIG waste of money! The best it registered was 190 HP and 300 TQ! The dyno operator said "not bad, how does it run?" I didn't say much, just "OK", and like Elvis, left the building......(BTW, it runs 11.8 in the 1/4mi.).....
.....I don't like Mustang dynos.......
