BBC Dimple rods, how good are they.
Old Dec 11, 2005 | 11:59 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default BBC Dimple rods, how good are they.
I am tossing around the idea of replacing the rods in my 454. They are BBC dimple rods with Milodon bolts (they may even be L-88 rods). They are definitely the weak link in my rotating assembly (steel crank, JE nitrous pistons, good pins, etc.) The reason for the possible swap is the fact I want to spin this motor to 7000+ rpms and hit it with a 250 shot. As all this is going through my head I am saving up my money to finish the 555 I am working on, so I would rather put the money there.
Who has spun the heck out of their dimple rods and had them survive. Any broken ones out there ??
Old Dec 12, 2005 | 12:19 AM
Corey_68's Avatar
Corey_68
The dimple rods are a LOT stronger than people think, We've ran these rods on blown 454 for tractor pull engines with no issues.
Old Dec 12, 2005 | 12:22 AM
GDaina's Avatar
GDaina
l88 rods are heavy, heavier than the dimple rods, use 7/16" bolts, the dimple's use 3/8" rod bolts...these were used on the 427/435 HP motors
Old Dec 12, 2005 | 02:04 AM
69 N.O.X. RATT
Mine have 7/16 bolts
Old Dec 12, 2005 | 08:08 AM
big632's Avatar
big632
Change out the bolts,On many aftermarket rods the bolt upgrade increases the hp limit,Call arp tell them what you have and want to do they will explain what is needed, probably arp2000 wav-loc or L19,We have a chevelle up here with those rods/bolts that sees close to7800rpm no nitrous, Is that converter trashed?
Old Dec 12, 2005 | 08:43 AM
69 N.O.X. RATT
Changing the bolts is a good idea, ya the converter is trashed. I pulled the tranny yesterday, metal shavings everywhere.
To BBC Dimple rods, how good are they.
