Power steering slave cylinder replacement
I had a leak in my power steering system a while back, it would be fine for a few days and then I would come back and all of the fluid would be drained out on the floor. I got under the car to see if I could tell where it was leaking from but everything looked worn out so I decided it was time to replace the cylinder and the hoses.
From what I read it is going to be more involved than just putting all the new parts on and bleeding the system. It will throw my front alignment off? I don’t understand what needs to be done other than installation. I will go read the Haynes Manuel (have not done that yet) and then will report back here with any questions. Any help would be appreciated. Thanks
James
These intermitent oil leaks are among the more anoying to fix. It could be a function of lod, worn rubber parts and seals, or it could be a flat spot in a rod from the slave, a shaft on the pump.....
