Torque Converter Not Locking Up
Old Dec 16, 2005 | 02:20 AM
DocSpeed's Avatar
DocSpeed
Default Torque Converter Not Locking Up
My buddies C3 torque converter won't lock up. I have seen several posts about this subject and all point to trying to hotwire the switch to make it engage at some point or another.
We have tried to hotwire the switch but it still won't lock up. Any other ideas/suggestions that we could try?
Old Dec 16, 2005 | 04:17 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
I didn't think C3s came with locking TCs.
Old Dec 16, 2005 | 06:00 AM
fl_rider's Avatar
fl_rider
What year Vette is it??
What transmission is installed?? 350TH? 400TH? 700R4?
Chris B
Old Dec 16, 2005 | 06:09 AM
Twin_Turbo's Avatar
Twin_Turbo
Late C3s (79 up?) came w/ th350c and 82 had 700r4, both w/ TCC
Old Dec 16, 2005 | 08:39 AM
DAVEWSC's Avatar
DAVEWSC
try this website, it may help you, http://700r4.com/faq/faq.shtml
Old Dec 16, 2005 | 09:34 AM
45ACP's Avatar
45ACP
The 350C was available starting with model year 1980.
Old Dec 16, 2005 | 11:05 AM
palazzopl's Avatar
palazzopl
I have an 81 with the same problem. Tryed grounding the groung wire that goes back to the computer still no luck, then I put a volt meter between the ground wire and a groung ,took it for a spin and watched the meter..It showed 12volts after it shifted into third. could be two things , dirt, or a bad soliniod..If you replace the soliniod replace the pressure switch also..
Old Dec 16, 2005 | 11:11 AM
gkull's Avatar
gkull
This summer my 700R4 torque converter lockup clutches went out. it's the second one in 17 years.
I've been able to get under the car and jumper on 12 volts and you can hear the seliniod pick and unpick. If you can hear the little clicks while your under the car chances are the lockup clutches went out. Then you just need a new TC
Old Dec 16, 2005 | 01:27 PM
CraigandJanet's Avatar
CraigandJanet
My 700R4 wouldn't lock when I got the car, and it ended up to be two problems. One was the upper brake switch with an electrical switch for the TCC and a vacuum breaker for the cruise control. It got bumped out of adjustment. After realignment, TCC worked (see below) and I got cruise control back.
My TCC would not lock unless it was a hot day and the engine well warmed up. I changed thermostats (mine was stuck open) and now the computer lets the TCC lock up as soon as temps get to normal.
I suggest looking at those two areas first, and it's likely one of them.
Old Dec 16, 2005 | 02:00 PM
comp's Avatar
comp
To Torque Converter Not Locking Up
