Steering Box Lubricant
Old Dec 18, 2005 | 10:19 AM
Ronnie wilkins's Avatar
Ronnie wilkins
Default Steering Box Lubricant
I have been reading threads about steering boxs.How do you check to see if it has grease in it. Is there a plug somewhere to fill it?Also what kind of lub should you use?Thanks in advance for any info.
Old Dec 18, 2005 | 12:16 PM
palazzopl's Avatar
palazzopl
if I find the way to put the lub in I'm going to use LUCAS rack lub
Old Dec 18, 2005 | 12:30 PM
StickShiftCorvette's Avatar
StickShiftCorvette
To check the box lube you pull the marked bolt and look in. To fill it you pull a second bolt, and make a bolt with a hole and grease zerk to inject grease until it comes out of the check bolt hole.
Old Dec 18, 2005 | 12:59 PM
GTR1999's Avatar
GTR1999
I'm going to disagree with the common method of removing a couple of the top bolts and adding grease until it comes out. This method is a crap shoot,if the worm nut is under the hole then you'll get a wrong indication, if you add too much it will blow out a seal. Removing the cover while the box is on the car will throw off the lash- if it's still correctly set.
I'd remove the box and then grease and rebuild/adjust it. That's the only way to correctly get the box full and set. All the boxes I rebuilt had dried out or just plain baked grease in them. It would have been useless with any of them to try and fill them through the cover.
Good luck
Gary
Old Dec 18, 2005 | 01:59 PM
75 Hot One's Avatar
75 Hot One
I'd be interested in hearing what people are using for manual steering box lube.
In the 1975 shop manual, a special manual steering box lube #1052084 is specified with the caution to not use it on earlier model years and not to use EP chassis lube. It so happens that this part # is discontinued and so is its replacement part #. The GM parts screen now specifies to use an EP chassis lube and "order direct from vendor" but gives no vendor or lube spec.
I used Pennzoil 707L chassis lube for my rebuild as recommended at a Bloomington clinic by an instructor named Harvey Jacobs who, as I recall, has a repair shop around Philadelphia.
Old Dec 18, 2005 | 04:43 PM
75 Hot One's Avatar
75 Hot One
An afterthought-This lube business seems to be a mess. I'd also be interested in knowing what's behind the seeming tight specs for the '75 manual steering box and why the GM reversal to go back to a chassis lube.
Old Dec 18, 2005 | 05:33 PM
GTR1999's Avatar
GTR1999
The GM stuff has been changed, I use Mobil 1 in all boxes 63-82. They are all the same as for seals and internal parts,only difference is the worm shaft and covers between the 63-E69 and L69-82's.
Old Dec 18, 2005 | 05:55 PM
Twin_Turbo's Avatar
Twin_Turbo
gary...you should know by now that synthetic isn't supposed to be used, it promotes wear and attrackts mositure...or so we were told in a thread some time ago (for those that fail to miss the pun...I too use mobil 1 synth in my rack, ball joints, cross shaft bushings and wheel bearings)
Old Dec 20, 2005 | 02:58 PM
ESU's Avatar
ESU
Do you mean regular mobil 1 motor oil??
ESU
Old Dec 20, 2005 | 03:04 PM
WESCH's Avatar
WESCH
Hi
No, not oil, but grease.
Mobli 1 grease. Synthetic water attracting rubbish .
:o
Günther
Old Dec 20, 2005 | 06:29 PM
palazzopl's Avatar
palazzopl
I used moble 1 gear oil ,should I drain it and use the grease and is it going to cause any damage
Old Dec 20, 2005 | 06:47 PM
ESU's Avatar
ESU
is 85w-140 gear oil OK?
Old Dec 20, 2005 | 09:04 PM
GTR1999's Avatar
GTR1999
No, gear oil will leak out regardless if the box is new or old. Use only grease.
Gary
Old Dec 21, 2005 | 08:22 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Old Dec 21, 2005 | 04:16 PM
palazzopl's Avatar
palazzopl
after I put the gear oil in I read your post,,Found the Moble 1 grease ,pumped it in and pushed out most of the gear oil then I used low pressure air to remove a little more and to leave room for expansion.. It tightened up my steering and took most of the play out.I just hope I didn't ruin anything with the gear oil.
Old Dec 21, 2005 | 04:22 PM
Brandywine's Avatar
Brandywine
Good luck
Gary
...and if you have headers installed, they will bake the lube fairly quickly.
Old Dec 21, 2005 | 04:54 PM
GTR1999's Avatar
GTR1999
You won't ruin anything in the box but it may leak out- depending on how tight the bottom seal and bushings are.
Gary
To Steering Box Lubricant
Old Dec 21, 2005 | 04:55 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
..... All the boxes I rebuilt had dried out or just plain baked grease in them. It would have been useless with any of them to try and fill them through the cover.
Good luck
Gary
Gary do you suppose you could work your magic on a 37 ford steering gear box if i decide to keep it?
Old Dec 21, 2005 | 05:15 PM
GTR1999's Avatar
GTR1999
Hi Bob, thanks for considering me but I'd rather work on the things I know well. The 37 Ford is notone of them I wonder how much different they are and are part kits available?
Gary
Old Dec 21, 2005 | 05:51 PM
palazzopl's Avatar
palazzopl
Gary , Thanks for the help.. MIke ..Southeast Florida
