E Brake Problem
Old Dec 18, 2005 | 09:25 PM
frostbitten09's Avatar
frostbitten09
Default E Brake Problem
Ok on my 78 vette, i just purchased it. Well i have my BRAKE light(red light black letters) Lit up when i start the car. I have my ebrake down and i put it up and back down numous times.
I think my ebrake is sticking or something else is wrong Does anyone have ideas??
Old Dec 18, 2005 | 09:43 PM
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
Have you checked the level in th M/C? look for any leaks or puddles on the ground too. DB
Old Dec 18, 2005 | 09:44 PM
frostbitten09
m/c??
Old Dec 18, 2005 | 09:55 PM
scotty13's Avatar
scotty13
master cylinder.....
Old Dec 18, 2005 | 10:10 PM
frostbitten09
oooo i feel dumb. Sorry.
Old Dec 18, 2005 | 10:21 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I don't remember any type of fluid level sensor on the master cylinder - I may be wrong but I don't think there's anything...
I suspect there's a switch that's closing the electric circuit to the bulp as soon as you lift the emergency brake. Maybe it's loose ???
The emrgency brake is inside your rear brake rotors, not too easy to replace - especially because you have to drill the rivets out of the rotors to get the rotors off.
If it works, don't mess with it
Old Dec 18, 2005 | 10:28 PM
Retro78's Avatar
Retro78
Two items can cause the light to come on. (1) emerg brake handle switch (2) hydraulic system failure in either the front or rear circuits(triggered by the proportioning valve).
Old Dec 18, 2005 | 10:43 PM
colorado1967's Avatar
colorado1967
Easy place to start is with the e-brake handle switch which is located under the brake console. It works just like the brake pedal switch
with a plunger and should be pushed in by the handle when the e-brake is off.
Look to see if it is loose or needs adjust.
Old Dec 19, 2005 | 06:18 AM
kb2fzq's Avatar
kb2fzq
My first obvious question...have you driven the "new" car and do you have spongy brakes or are they stopping the car correctly??
Old Dec 19, 2005 | 03:06 PM
frostbitten09
Well i need to fix the ujoints, THen i can drive it without worries. It is driveable but i was told it needs a ujoint, so im not going to push it and have a chance of breaking more things.
Old Dec 19, 2005 | 03:41 PM
kb2fzq's Avatar
kb2fzq
I must admit, from my experiences, if you have general bad brake problems, low fluid, air in line, bad shoes, etc, the light should only come on when the peddle hits the floor, and usually should pump up temporarily...but you're saying the light is on constant?? Without starting the car and pumping the brakes, it could be a bad sensor in the proportional valve, or bad switch on the e-brake, or bad switch on the brake peddle...hard telling from here...I'd try and localize at the switches by unplugging the switches and see if the light goes out...if not, the fluid sensor maybe bad...hard telling...maybe somebody else can better advise...I had air in the front lines, bleed them and the brake light never came on again (they had been going to the floor) and brakes have been good...
Old Dec 19, 2005 | 06:36 PM
Blue 74's Avatar
Blue 74
My brake light stayed on all the time. I replaced all calipers, shoes, hoses and pads. Jacked with E-brake switch and it still stayed on. As soon as I re-centerd the proportional valve the light went out. Cause/effect ? Luck? Chance? Whatever, it worked.
To E Brake Problem
