differential side yolk replacement procedure
Old Dec 19, 2005 | 11:51 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Default differential side yolk replacement procedure
Im going to be replacing my differential side yolk on my passenger side whenever it gets here from Ecklers.
Any tricks to doing this. I know I need to remove rear spring, remove the half shaft, support diff, remove rear cover and frame mounts etc. But after that, I'd just have to see what It looks like inside.
Old Dec 19, 2005 | 11:54 PM
ruby76's Avatar
ruby76
sorry, yoke not yolk. We're not talking eggs here.
Old Dec 20, 2005 | 02:39 PM
GTR1999's Avatar
GTR1999
How's this, also you'll have the posi springs and plates in there.
Gary
Old Dec 20, 2005 | 06:11 PM
flynbyu82's Avatar
flynbyu82
You just unclip the C-clip and they come right out... when I replaced my differential, I had to use my old yokes. The C-clips were covered in fluid, so I had no idea how to get the yokes out. I just went beating away
Old Dec 21, 2005 | 08:40 AM
ruby76's Avatar
ruby76
Gary
Worth a thousand words. I hadn't really thought about it, I guess I'll need a snap ring tool to remove the c-clip - another trip to the tool depot!!!!
Old Dec 21, 2005 | 08:50 AM
DansYellow66's Avatar
DansYellow66
While your at it you might as well replace the side yoke oil seals too - pretty easy and inexpensive at this point in dissassembly.
Dan
Old Dec 21, 2005 | 02:00 PM
ruby76's Avatar
ruby76
right, I ordered,the yoke, new c clip, new oil seal, and differential cover gasket.
Old Dec 21, 2005 | 05:22 PM
GTR1999's Avatar
GTR1999
you'll need a GOOD pair of 90* snap ring pliers. I used the get a cheap looking pr of pliers from my bearing supplier 25 years ago that was the best I ever used. I don't know if they're still made- probably not, but they were the best. I still use them. Sears had a good industrial set a couple of years ago but I never used them for this job.
Check the yoke seal OD too, some are .010 oversize and they are a bear to install without distortion. NAPA sells the yoke seals#13562 and they are made by CR seal.
Gary
Old Dec 22, 2005 | 08:38 AM
ruby76's Avatar
ruby76
Thanks guys. I appreciate everyone's replies. I like to know what to expect before I tear into it. Too bad the yoke is on backorder or I'd get into it b/n Christmas (yes I said Chrismas) and New Years since I'm on vacation that week.
Thanks again!!
Old Dec 22, 2005 | 12:32 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
You should of gotten them from me. I have them in stock. SB or BB.
Old Dec 22, 2005 | 04:39 PM
ruby76's Avatar
ruby76
DOH!!! how much for a SB side yoke. Maybe it isn't too late to cancel!!!
Old Jan 22, 2006 | 08:03 PM
ruby76's Avatar
ruby76
In one of the pictures above it looks like the yokes are sitting against that middle section, (sorry, don't know the terminology) Is that where the wear takes place, on the end of the old yokes?
Jeremy
Old Jan 22, 2006 | 10:56 PM
bahamasair's Avatar
bahamasair
The wear takes place on the edge of the yoke that rubs on the outside of the dif case. The end of the yoke that has the C clip on it will hit into the rod you see in the pic that runs down the middle and will cause the end to mushroom. One of mine was mushroomed pretty bad to the point there was no way it was going to pull out. I used a chisel and went round the end mashing everything down enough to be able to hammer out the yoke.
Old Jan 28, 2006 | 08:36 PM
ruby76's Avatar
ruby76
Yep, that was it, it was worn almost to the grove for the clip. The other side DIDN"T HAVE THE CLIP in place !!!!!! The clip was wedged into one of the posi springs. Glad I took it apart to replace the one yoke, now I've got it all squared away and ready to go back in.
Old Jan 29, 2006 | 09:33 AM
69monzaredbigblock's Avatar
69monzaredbigblock
Did the same job recently with Forum and a local club members help. It went pretty smoothly. I did find that the rear spring to diff bolts were only engaged by two threads. I replaced them with longer gr 8's but not too long so they would bottom out in the forward diff holes. I did not see any mention of it in my GM overhaul manual but my 69 AIM says this " Bolt (rear spring to diff) must be torqued with spring compressed to design height " I interpreted this to mean bolts should be torqued with weight on wheels. I hope I did it right! If not some one let me know.
Old Jan 29, 2006 | 10:10 AM
ruby76's Avatar
ruby76
Did I mention that freakin differential is very HEAVY.
Old Jan 29, 2006 | 11:07 AM
gator79's Avatar
gator79
I did mine yesterday. I removed the center pin to make it a little easier.
be careful because one of my spider gear thrust washer came out. that was fun to put back. I changed both shafts and seals and replaced the front seal also. but my differential is out of the car already, so it was easy
To differential side yolk replacement procedure
