What are the mounting dimensions that limit the speaker choice?
Will any 4x6 fit as long as its shallow enough? And what is that depth? Or is there some other restriction?
Does anyone have Kenwood 4x6 KFC-4675C speakers in the kick panel of their Vette? Apparently these are the same speakers that Paragon sells.
I am looking for something resonably cheap, and the Crutchfield website says these will fit. Does anyone know first hand weather they will fit without cutting or altering anything on a 69.
Yes, the Kenwoods will fit....I had those in my '69 before I upgraded to speakers with a higher power rating.......there's plenty of room in the kick panels for just about any 4x6 speaker.
My Dad is actually a speaker engineer, so if anyone has any very technical questions about this, keep me in mind.
For the front I'm using Eclipse 4x6s they sound good, better than most. The Eclipse drivers are pretty deep, relative to most 4x6s, so I don't think that depth will be an issue. Whatever you do, stay away from those dual tweeter co-axials, they suck. The woofer makes most of the midrange and if you have to much bling mounted infront of it, it will sound like ****. And the tweeter should be either 1" or 3/4" preferably silk dome, stay away from those cheesey tin ones.
Kick panel speaker loc. (77 measured) about 5 3/4 H X 4 W X 2 1/4 D.
4X6 fit easily, 5 1/4 can be fitted. A mounting plate is needed.
Lightweight Kenwood eXcelon dualmag comps 5.25.
The engine makes enough music for me.
Thanks. The 427 makes plenty of music for me too. Just want to have a radio in there for longer trips. Does anyone know if the opening in a 69 kick panel is the same size?
