Check out these fans
Chris
Make sure you post a follow up. Most guys just seem to disappear after a post like this one and we never see the end result of their project.
Good Luck, Les
http://www.et-motorsports.cc/new_pic...new_fan_01.jpg
http://www.et-motorsports.cc/new_pic...new_fan_02.jpg
BTW 442olds that fan housing is saweet!
Chris
off of 93-97 camaro/firebird and they fit perfect with a shroud.
All you have to do is fab some brackets, and they pull air like crazy.
they look like crap now, but everything will be taken apart and painted
when the weather gets a little better for me
the fans came with the donar car. you can see here on page 4/5
http://www.cardomain.com/ride/336959
I commend you guys on your fabrication work, but have to inform you both that they will not be as efficient as you would like. Because the C3 Corvette is about the only car ever made with a radiator that is not vertical, the air has trouble flowing through them and they can be a bitch to cool.
Boofers, if you could fill in that area between the o.d. of your fan and the i.d. of your shroud, it would be a lot more efficient as ALL of the incoming air would then be forced to go past the fan. As it is, the fan can pull air from BEHIND the radiator, i.e. the engine side, around the o.d. of the fan and then back through yhe fan when the car is at rest or travelling slowly, and pulling very little air through the radiator. At speed, you won't have that problem but it's when the car is stationary or moving slowly when you need it most.
Evalu8r, pretty much the same with your set up, although your fans appear closer to the radiator and should work better than boofers' set up. But not as good as if they were mounted in a closely fitting shroud that allows the fans to pull ALL of their air through the radiator.
I used to sell diesel engines and we had to know a lot of stuff about cooling fans, shrouds, air flow, etc. Good luck with your projects.
Regards from Down Under
aussiejohn
Anyways, thanks for the tip buddy. I will give it a shot.
Chris
Chris
