best driveshaft
it must be lightweight and be able to survive to a 575hp 550tq engine, 4 speeds manual, 3.73 gear, driven on street tires though, thanks.
Diameter means alot in tubing.
I posted on modifying the drivers side motor mount so it allowed the transmission to be centered in the tunnel.
I wonder about your drive train alignment???
My 3 inch shaft is centered in the tunnel and I could fit a 3 1/2.
The transmission isn't centered in the tunnel, it's offset. this way there's a sideways angle from trans to diff, it's supposed to be that way. Our cars have a centered pinion on the diff because of the IRS and the requirement for symmetric left 7 right sides there but putting the trans driveshaft centered so the engine sits in the frame at an angle is just weird, it's not supposed to be that way.
I actually strung my car. YOu run a string down the center of the car using the crank dampener on the front and the center of the rear housig on the back for start and finish. You then drop plump lines from the various places and see how they line up.
Bet most of your drivetrain isn't in a straight line. In jogs back and forth.
I am well aware of the offset, I have a big blower sticking through the hood that points that out all the time.
I also hang around a race shop and they taught me about stringing a car and aligning the drivetrain.
Wouldn' t it be nice if the crank, the transmissionl, the driveshaft and the pinion all lined up???
Won't happen unless you do something about it.
I took the time.
The driveshaft is angle in only one direction, That is down. I didn't want mine angle sideways and up and down.
From a birds eye view with the body removed you want the entire driveline to look like it is in a line.
You will find the tailstock points off towards the back passengers tire and the pinion point to the passengers front tire.
Extend a rod out the back of the tailstock and another out the centerline of the pinion and they look like crossed swords.
This doesn't add to a smooth running drivetrain.
GM moved the tunnel towards the passengers side to compensate for the motors offset. Ideally the drivetrain runs down the center of this tunnel.
I had to work at correctly my alignment but it is true front to back looking down from the top. Involved pulling the rearend and slotting and eventually redoing the holes in the rear crossmember .
What this accomplishes is a smooth running drivetrain. No slight shimmy of the shift handle and no vibration anywhere.
I could also get by with a 3 1/2 inch driveshaft if I wanted.
Actually for the appication described, I would suspect a steel driveshaft with a little extra diameter would be just fine. There's no use looking for an aluminum or composite fiber driveshaft if you're using a 15 pound iron flywheel, a 5 pound steel damper (?), and a steel crank that weigh how many pounds? How much does a SB crank weigh? 40 pounds? I would guess a BB crank is around 60 to 70 pounds. If you want to reduce rotating mass, there's no use buying an expensive low weigh driveshaft with all these other heavy rotating components in your drive train.
Anyhow, all that being said, low weight is a good thing. So if you're going to install an aluminum driveshaft good on you. Have you looked into an aluminum flywheel? If you want to reduce rotating mass and overall car weight, perhaps I this may be the low hanging fruit to pick.
i have a new 11'' McLeod steel flyw, this is what the engine builder advice me to get for the engine application, will an alu flyw be good enough? what brand/seller? i'm very interested in keep dropping the car weight, i guess i'm already at around 3.000 lbs...thanks
