Correct Sway Bar Size???
Old Dec 22, 2005 | 01:40 PM
hosspowerinc's Avatar
hosspowerinc
Default Correct Sway Bar Size???
Im almost ready to put my body back on and havent really figured out what size sway bars to use. Now I dont want the debate about you shouldnt need them blah,blah,blah. I know they are used to compensate poor suspension design. My corvette has poor suspension design. There I admit it. Im not about to refab it so what rates work? I have a 77 with 550 springs up front, a composite 360 in the rear, poly bushings, plan to up size the wheels to 17 or 18 inchers, smallblock with a in the works t5, and new everything as far as steering. Im very much into autocross and road racing so I will want something stiff with just a bit of understeer. Thanks to all in advance!
Old Dec 22, 2005 | 02:00 PM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
Not too many "modern" vehicles I know that doesnt have anti-sway bars...that being said; its really not because of "poor suspension design" or that would be said of all modern cars and trucks.
As far as diameter and lengths goes; it will kinda be a crap-shoot until you have all components on, and vehicle road tested to know your "specific" needs...all road racing components act differently per vehicle.
Different tires will corner better or less; requiring more or less anti-sway.
Different vehicle weight, different rim offsets and COMPLETE wheel heights; all factor in to "what is needed" vs. "what is already bought, and/or will be installed".
Heck; even certain roads require more or less anti-sway.
I know thats not a lot of help...you could always start with the stock bar with the poly's, and decide where to compensate from there.
Jim
Old Dec 22, 2005 | 02:24 PM
norvalwilhelm's Avatar
norvalwilhelm
You already have 550 pound springs, your sway bar won't be as effective as running light springs and a heavier bar.
550 pound springs tie up the suspension so pot holes and bumps cause the tire to skip over the road surface but it does mask alot of the problems
Old Dec 22, 2005 | 02:33 PM
gerry72's Avatar
gerry72
There are books on suspension design that will allow you to approach this intelligently.
Just off hand, though, with 550 in/lb front springs and 360 in/lb rear, you're probably going to want to go to a small bar and tune the suspension with shocks. I'd start with the stock bar(s) and test it out before throwing money at it. You may end up needing nothing or only shocks to get it where you want it.
Old Dec 22, 2005 | 02:38 PM
hosspowerinc
Thanks for all the replies. I have always thought that those rates were the normal for a decent handling suspension. What rates are you guys running?
Old Dec 22, 2005 | 02:58 PM
gerry72's Avatar
gerry72
550s up front with factory small bar, factory steel 9-leaf in the rear with no bar, and KYBs all around. All poly bushings and tubular tierod centers up front as well as bb idler. Rear is just a Guldstrand strut assembly.
Nothing real fancy. Works for me. May not be right for you.
Old Dec 22, 2005 | 03:21 PM
supervett77's Avatar
supervett77
im running the same spring rates also, im gonna shoot for the bilstein gas shocks. Sounds like you need a set of these babies. It that isn't enough then go for stiffer sway bars i would say. A vehicle like that will not have a lot of body roll thats for sure.
Old Dec 22, 2005 | 04:26 PM
Hauq`'s Avatar
Hauq`
I have the same spring rates. The VB&P slalom suspension package comes with a 1.25” sway bar up front, and a .75” in back. I just put the body on, and can’t tell you how good they are yet.
Old Dec 22, 2005 | 05:01 PM
gkull's Avatar
gkull
I have a lightened Vette. Smart Struts With 550# F and @420# R 1 1/8th front sway 3/4 rear sway both with spring end adjustables. 17 inch wheels 9 & 11 inch I would recommend 18 inch wheels do to better tire choices.
I would maybe use a 5/8th rear bar and I would even consider 600+ springs on the front end if your road racing track has any kind of long banked turns. Because I managed to blow out a front shock out on the track this spring and had to resort to a small spring shim on the A-Arm to lift the front end.
Old Dec 22, 2005 | 05:10 PM
hosspowerinc
I most likely will be into the high 500's low 600's when I get the ride height set. What size tires are you running in the rear? I was going to ask if you had any oversteer but with an 11 inch rear wheels Id say you have enough traction to handle the swaybar and high spring rate. Have you played with any other combos?
Old Dec 22, 2005 | 05:44 PM
Glassbowtie77's Avatar
Glassbowtie77
I have 550lb VB&P springs up front and I am running the stock 1-5/8" sway bar up front that came on the car originally along with poly bushings.
Old Dec 22, 2005 | 05:48 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Im thinking about going with 600 pound springs that will be 650 fter i cut them.
Old Dec 22, 2005 | 05:59 PM
70 LS1's Avatar
70 LS1
I plan on using 460 fronts, stock style 7-leaf in the rear, 1.25" bar up front and Bilstein shocks. I like the idea of softer springs and bigger sway bar.
Old Dec 22, 2005 | 06:07 PM
gkull's Avatar
gkull
rear tire size - I have 315/35/17 But the wheels add three inches of rear track per side. The additional 6 inches of rear track cause additional leverage on the 420 inch pound spring so the ride is pretty compliant. I've considered different sway bars, but the spring end adjustables you can make both the front and rear not react to small tire verticle movement and then they come in once it's spring is compressed. My rear is very stable through a turn
Old Dec 22, 2005 | 08:25 PM
73jst4fun's Avatar
73jst4fun
I'm running the 460 springs cut to lower the front end, 1 1/8" front sway bar, composite rear spring 360 lbs., and a 3/4" rear sway bar with Bilsteins all around with 60 series BFG's......handles great with this combo..........
Old Dec 22, 2005 | 11:39 PM
wb6mfw's Avatar
wb6mfw
On my '81 it is 1 1/4" at the front and 7/8" at the rear. I just added the rear sway bar and it makes the car handle a lot better in the turns. That combo worked great for me.
Bill
Old Dec 23, 2005 | 02:53 PM
gkull's Avatar
gkull
You might want to measure your bar. I'm pretty sure that stock bars were all less than one inch dia. on any C-3. I have or had a 79 L-82 with the suspension package and the 1 1/8th made my stock bar look wimpy. The 1 1/8 and 1 1/4 are actually heavy to pickup.
To Correct Sway Bar Size???
Old Dec 23, 2005 | 09:10 PM
73jst4fun's Avatar
73jst4fun
Anyone have any info on the Addco sway bars, I've heard they are an alloy material and maybe hollow which would save some weight.....Hotchkis sway bars are hollow but pricy, don't know if they make them for vettes...
Old Dec 23, 2005 | 10:56 PM
hosspowerinc
My stock bar is 7/8 so I guess I will be using it as a starting point. Ill just see how sticky the tires are and go from there. Thanks for all the help! Justin
Old Dec 23, 2005 | 11:48 PM
Glassbowtie77
My front sway bar is 1-1/8". I measured it when I ordered my poly bushings, and yes it is quite heavy.
