Spindle Set up Tool Help
Old Dec 23, 2005 | 01:54 PM
Burnt71's Avatar
Burnt71
Default Spindle Set up Tool Help
I'm having trouble trying to figure out where to measure my end play. I put the bearings and spacer on the tool and when I tighten the nut there is nothing to measure , Its tight on the bearing. Why do I need to torque the nut when it goes down tight against the bearing . Where should the .001 gap be ?
Old Dec 23, 2005 | 02:50 PM
GTR1999's Avatar
GTR1999
Call me before 3:00 today and I'll help you.
Gary
Old Dec 23, 2005 | 03:29 PM
Twin_Turbo's Avatar
Twin_Turbo
You put the 2 bearings, the spacer and the shims into the hub after tapping in new races, then you torque down the tool and measure the end play.
http://www.montygwilliams.com has a good write up w/ pictures.
Old Dec 23, 2005 | 04:11 PM
Burnt71's Avatar
Burnt71
I know what I was doing wrong . I'm glad I stopped. I'll let you know how I make out Thanks guys.
Old Dec 23, 2005 | 08:58 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Make sure you pack the bearings before you do anything.
Old Dec 24, 2005 | 01:21 AM
Twin_Turbo's Avatar
Twin_Turbo
Do you pack them before setting the play?
I set them dry, I just lightly coat the bearing and race with some light machine oil
Old Dec 24, 2005 | 09:28 AM
Burnt71's Avatar
Burnt71
Yes I'm havin'g trouble with by back seal , I can't get the splined yoke to push on past the rubber seal , I need to wait until next week to get a different type Of bearing seal.
To Spindle Set up Tool Help
