changing oils
Old Dec 25, 2005 | 05:12 AM
panic's Avatar
panic
Default changing oils
hi, could you pls advice me what are the best reliable oils for complete driveline (gear/etc), pls give me the tech details possible for mobil line or any other common brand in europe, thanks..
Old Dec 25, 2005 | 08:32 AM
rihwoods's Avatar
rihwoods
http://autorepair.about.com/od/motoroils/
Old Dec 25, 2005 | 02:20 PM
GaryS's Avatar
GaryS
I can't give you any technical data on oils but I use Mobil 10W-40 in my 72 Corvette and I use Mobil1 synthetic lubes in transmission and differential. The lube I use is Mobil 1 Synthetic Gear Lube LS 75W-90. Of course, I use GM Positraction additive in the differential too.
If you read Consumer Reports you will see that any name brand oil will suit your needs fine. Others will chime in about this oil or that oil being better, but I trust an independent lab, doing scientific analysis, over word of mouth.
Gary
To changing oils
