serpentine belt conversion?
Old Dec 25, 2005 | 03:28 PM
onaqwst's Avatar
onaqwst
Default serpentine belt conversion?
http://store.summitracing.com/defaul...=egnsearch.asp
here's the part number MCH-22020 link didn't go to the part
this is what i have been looking at for a conversion.....350 small block setup..... anyone have this setup....any precations i should take with this?
b
Old Dec 25, 2005 | 04:02 PM
napahead's Avatar
napahead
i did that to a 79 z28 i had but i used all gm parts off of a early 90's pickup
Old Dec 25, 2005 | 07:43 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Brian, I have the March 20450 kit on my car, the only snags I ran into were: the water pump pulley was not made for a water pump with a 3/4" pilot shaft, it is for a 5/8" shaft; and if you use an Edelbrock Victor series water pump like I did, you will have to do a little grinding to the arm of the pump because the power steering pump will hit the water pump because the Edelbrock pumps are very beefy in this area.
http://www.marchperf.com/pg13.html
Old Dec 25, 2005 | 08:14 PM
onaqwst's Avatar
onaqwst
i have to buy a new water pump also..... i had the wrong pump before..... fan didn't sit center and created alot of vibrations...... that was why i blew 2 wp gaskets and blew a few hoses from rubbing/etc.... time to upgrade and and some hp/chrome.....
stupid question....... if u have a serpentine setup, u would run electric fans...or could you run a flex fan.....?...... whats common procedure on this.......
b
Old Dec 25, 2005 | 08:32 PM
David Ey's Avatar
David Ey
I would run electric fans. I do not like flex fans at all.
Don't like the amount of belt contact on the power steering pump either.
Old Dec 25, 2005 | 08:44 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Yep ... they come apart.
Old Dec 26, 2005 | 01:35 PM
onaqwst's Avatar
onaqwst
so you are saying that the belt would have a tendency to slip off of the p.s. pulley?
i could just upgrade my v-belt pulleys but i'm sort of looking for a kit to help clean up the bay......
b
To serpentine belt conversion?
