gear and diff oils
Old Dec 27, 2005 | 06:19 AM
panic's Avatar
panic
Default gear and diff oils
hi, would you advice as gear (T-10 manual 4 speeds trans) oil the castrol 75/90 fully sintetic and same lube but 90 sintetic for the diff? the seller claims i won't need any additive, that this diff oil is already ready for use streight away...what do you think? thanks/Giuseppe
Old Dec 27, 2005 | 07:30 AM
pws69's Avatar
pws69
I would use the GM Posi additive anyway - I won;t hurt. I don't believe Castrol has any/sufficient additives.
Old Dec 27, 2005 | 07:37 AM
mrvette's Avatar
mrvette
I think any 30 weight synthetic engine oil is fine for a stick shift tranny, of any vintage...I put it into my Muncie some years ago and drove it for about 2-3 years, it smoothed out the shifting something wonderful.....
I have heard of oils light as ATF in differentials...not sure about the posi thing though.....frankly some posi additive and a load of 30 weight synthetic engine oil is what I"d use, and intend to use next time I have that diff out....
GENE
Old Dec 27, 2005 | 07:50 AM
GTR1999's Avatar
GTR1999
I only use the old 90 wt gear oil in both manual and differentials. I use 2 bottles of additive in the differential.
Gary
Old Dec 27, 2005 | 07:55 AM
Gordonm's Avatar
Gordonm
Gary
That is what I use
Old Dec 27, 2005 | 08:16 AM
PEPTO77's Avatar
PEPTO77
What is the best way to get the old diff fluid out and the new fluid in?
Old Dec 27, 2005 | 08:19 AM
comp's Avatar
comp
i always use additive
Old Dec 27, 2005 | 08:49 AM
panic's Avatar
panic
thanks for the infos, but what is the use of the additives on the differential? why a simple diff oil won't do? just a curiosity...actually i cant easily find this GM additives where i live at the moment...that's why i was looking for an alternative..
Old Dec 27, 2005 | 08:53 AM
Gordonm's Avatar
Gordonm
The posi additive is for the posi clutch plates. You might find that you have chatter if the additive is not used.
Old Dec 27, 2005 | 08:55 AM
Gordonm's Avatar
Gordonm
I drilled and tapped my carrier while I was changing gears so I now have a drain plug. If no drain plug remove the plug in the diff cover and get a "sucker" or something to suck the fluid out. This will not get it all out but the majority of it will be sucked out. Then refill in the same filler hole. Only fill until some fluid comes out the hole. It is then full.
To gear and diff oils
