Engine Change
Old Dec 27, 2005 | 10:30 AM
b-line's Avatar
b-line
Default Engine Change
I am about to pull the engine and transmission from my 71 350/auto. I am wondering how high up off the ground do I need to get the car? I have a engine hoist that will allow me to tip the engine and tranny for removal. I am building some sturdy wood platforms to set the frame on when I get the car up in the air that are about 16" tall. Will this allow enough ground clearance to remove both engine and tranny?
Old Dec 27, 2005 | 10:39 AM
BKbroiler's Avatar
BKbroiler
You can still jack up the front end while you're pulling the engine and trans. You are probably going to have to remove the fan shroud and radiator for clearance.
I removed motor and trans separately and didn't have to remove the shroud and radiator.
Old Dec 27, 2005 | 10:41 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the engine comes out from the top....our car is almost resting on the engine hoist legs and you have to make sure the front rotor and backing plate to do not rest onthe engine hoist legs, we took the trans out through the bottom , but would not do that again. we installed the new engine and trans together
Old Dec 27, 2005 | 10:59 AM
b-line's Avatar
b-line
I should have included in my message that I intend to replace the radiator so yes I will be removing the hood and radiator shroud at the same time.
Old Dec 27, 2005 | 12:12 PM
redc3's Avatar
redc3
am confused why you want to jack the car up? no need to jack it up at all other than a-arms hitting the hoist legs, but you can get that clearance by grabbing the fender lip and pulling up. you will find however that you will need a really long hoist to grab engine from the front. even if you have one you may need a buddy to stand on the other end to counter balance it. ( i used one of my kids ). you can pull the tire and pull from the side if you have enough room to back the hoist away on solid ground.
Old Dec 27, 2005 | 12:23 PM
fl_rider's Avatar
fl_rider
I pulled the left front tire and went in from the side to pull my engine by itself.
My hoist wasnt long enough to go in from the front.
I just supported the trans on a jack with a board on it.
Chris B
Old Dec 27, 2005 | 12:29 PM
ltlevil's Avatar
ltlevil
I think he is concerned with the angle of the tailshaft and clearance between the ground and tail shaft when tilting the engine/trans assembly. If you have enough room to work under the car and unbolt everything you will have enough room do what you need to do to get engine and trans out. Last time I put mine in I didn't even take out the crossmember and there was no drama involved, matter of fact I didn't take out the radiator either now that I think about it.
ltlevil
Old Dec 27, 2005 | 01:26 PM
Z-man's Avatar
Z-man
Part of the answer depends on how long the arm on your hoist is...i.e. can you get the engine high enough from the front. I have a small block and got the engine and transmission in and out from the front while the car was on jack stands (probably not far from 16" up). I also used the engine "leveler" or whatever it's called and didn't have to remove the radiator support (although it cleared only by a half inch). You should have no problems if the radiator support is gone. I also had no assistance and it wasn't that bad. I've got some shots here:
http://temp.corvetteforum.net/c3/zma...ginepage04.htm
Old Dec 27, 2005 | 01:50 PM
bobs77vet's Avatar
bobs77vet
heres our stuff going back in....we started from the front and then we pulled the engine hoist over to the side to finish the job the rest of the way.... our radiator was out.
[IMG][/IMG]
Old Dec 27, 2005 | 04:08 PM
b-line's Avatar
b-line
You got it "ltlevil" ground clearance when pulling both engine and trans. However, after reading yours and bobs77vet threads it sounds like I can do it without having to get the car very high up. I don't like the idea of working under the car while it is on jack stands so I am in the process of building some wood platforms for the car to rest on that will I hope stabilize it for some other work I need to do. I will take it out from the side as you suggest. The new engine is a 383 stroker from Tand L Engines in N. Carolina. Also, thanks to bobs77vet for the pictures. You have further inspired me to go forward with the project.
Old Dec 27, 2005 | 04:17 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
[IMG][/IMG]
Looks like you have the core support out also
I just pulled my motor out this monday. All you have to do
is take one wheel off and pull both the motor and trans at the same
time. I will post pictures tomorrow the car does not need to be jacked up.
You can do it without having to pull the core support.
Old Dec 27, 2005 | 11:03 PM
MEGALADON's Avatar
MEGALADON
Just take one whell off, so you can position the hoist at an
angle. Works perfect. I got my son doing all the hard work
Old Dec 28, 2005 | 09:48 AM
b-line's Avatar
b-line
MEGALADON:
I saw your thread on the engine removal along with the pic's. Looks like this job isn't going to be as bad as I thought. Just a lot of labor. Thanks for the help and by the way I am on the north side of Houston(Kingwood) if you are familar. Isn't it great to have built-in help?
Old Dec 28, 2005 | 01:08 PM
MEGALADON's Avatar
MEGALADON
MEGALADON:
If you want some help, e- mail me or PM me
Old Dec 28, 2005 | 10:09 PM
bobs77vet's Avatar
bobs77vet
yes my core support was out also. and that is the time to do anything you need to with the headlights....
[IMG][/IMG]
To Engine Change
