Control Arm Dimensions?
Old Dec 27, 2005 | 08:14 PM
eddiemeddiem's Avatar
eddiemeddiem
Default Control Arm Dimensions?
After removing the control arm bushings, it seems that I've spread (bent) the control arms when the cross shaft is installed. Before I spend a few hundred dollars on a new set, I'd like to attempt to bend them back into shape with a press. Does any one know the dimensions of the spread of the upper and lower control arms? If someone is kind enough to measure these for me, please specify if this is the inside dimension, or the outside dimesion.
Thank you for any help!
-Eddie
Old Dec 27, 2005 | 11:44 PM
yukon988's Avatar
yukon988
Try this:
http://www.corvettefaq.com/suspdim/index.htm
Old Dec 29, 2005 | 02:56 PM
eddiemeddiem
That's exactly what I was looking for - Thank you!
-Eddie
To Control Arm Dimensions?
