Heater Core cover caught on something.
Old Dec 27, 2005 | 09:53 PM
enkeivette's Avatar
enkeivette
Default Heater Core cover caught on something.
I separated the heater box from the firewall and moved the top a few inches back. But something is caught on the bottom preventing it from breaking free of the firewall. What is it and how do I get it off?
Old Dec 27, 2005 | 09:57 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Unfortunetly I have a lot of experience in this. One did you get the nut/ stud off on the utmost right side by the blower motor? If you have verified all 5 nuts are off on the engine bay side then rock it up and down. The studs were bent on both my Vettes and required some "encouraging" to remove.
Old Dec 27, 2005 | 10:12 PM
Hammerhead Fred's Avatar
Hammerhead Fred
What year are we talking about and which side of the firewall are you working from? Are you pulling the heater duct from inside the car OR are you pulling the blower box from the engine compartment?
Old Dec 27, 2005 | 10:23 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
If you are pulling the heater core from inside the car then the feed tubes are probably what's hanging up. Make sure you have removed any & all clamps, etc. While pulling up on the core/box also rotate the assembly slightly towards the rear of the car, it should slide out. I should note that my dash was completely out when I did this so I had lots of room to work. If you are not reusing the core, you might consider cutting the core tubes as high as possible, from underneath the car. This would ease the extraction process.
Old Dec 27, 2005 | 11:22 PM
canucbuck's Avatar
canucbuck
Need to know the year.
Old Dec 27, 2005 | 11:32 PM
yukon988's Avatar
yukon988
I just did this a few days ago on my '72. I had the same problem. You have to rotate the box (top toward you, bottom left against fire wall) to get he feeder tubes to come up and out. I did it without cutting the tubes.
Old Dec 28, 2005 | 12:55 PM
Cali,68,L-79
absoluely no reason to cut the tubes. I first pulled the outer core box with blower and htr core motor out from the engine bay side and then I pulled the inner box from the interior of the car.
Old Dec 28, 2005 | 01:16 PM
camaroneil's Avatar
camaroneil
mine (77) had a tiny screw towards the bottom,
it was almost impossible to see,
natt
Old Dec 28, 2005 | 05:03 PM
enkeivette's Avatar
enkeivette
Thanks guys, I'll try rotating it. It's a 78 with AC, and I'm working from inside the car.
Old Dec 28, 2005 | 09:55 PM
enkeivette's Avatar
enkeivette
I forgot to take off the hoses first... duh. Does it matter which hose goes where? Is one in and the other out?
Old Dec 28, 2005 | 09:59 PM
yukon988's Avatar
yukon988
On my '72 it looks like they are different sizes so I am guessing that there is one in and one out.
Old Dec 28, 2005 | 10:09 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Be extra careful when putting the hoses back on. Try to support the core inlet/outlet as you put the hose on so you do not break the solder joint at the core. Been there, done that.
Old Dec 28, 2005 | 10:12 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
The heater hose off the water pump is 3/4" and the hose off the intake is a smaller 5/8".
Greg
Old Dec 28, 2005 | 11:24 PM
canucbuck's Avatar
canucbuck
Just did mine a couple of months ago on my 79. I took alot of pictures along the way. When I put the hoses back on the tubes I lubricated the inside of the hoses with margarine and they went on real slick. But before you put everything back together start it up to make sure it does not leak. It has been known that you can be sold a bad heater core.
Old Dec 28, 2005 | 11:28 PM
Cali,68,L-79
Like I said been there done that.
make sure you don't have a small dog stuck in your heater box.
To Heater Core cover caught on something.
