Carb spacer Question
Old Aug 3, 2001 | 01:30 PM
The Wanderer's Avatar
The Wanderer
Default Carb spacer Question
I received my carb & distributor back from Lars and am about to install it. I have a quick question that I forgot to ask Lars. I have what appears to be a phonolic spacer between the intake and the carb.
My question is... it didn't have gaskets on either side of it. Does it self-seal itself? Should I use gaskets? Should I replace it with a new one, assuming one is available. It appears to be in good shape, but does have indentions one both sides matching the indentions of the intake and carb.
Thanks, Dick
Old Aug 3, 2001 | 02:10 PM
gerry72's Avatar
gerry72
Default Re: Carb spacer Question (The Wanderer)
It's an organic fiber insulator/gasket, not phenolic, Dick. It is the gasket and requires no other gaskets. The rings inserted into the gasket keep you from using your super-human strength to crush and split the gasket or crack your throttle plate.
Old Aug 3, 2001 | 02:26 PM
a smith's Avatar
a smith
You should put a new gasket on.You should be able to get a new one at just about any auto parts store
.The new gasket will probably be made out of a grey gasket type of a material.It will work better that the old one.
[Modified by a smith, 12:30 PM 8/3/2001]
Old Aug 3, 2001 | 02:59 PM
The Wanderer
Default Re: Carb spacer Question (gerry72)
Thanks for the reply. I ran into town to grab a burger and stopped by AutoZone and bought a new one. You are right, the new one is grey.
To Carb spacer Question
