I am in the process of removing my front springs so I can lower the car a bit, In the process of separating the lower control arm from the spindle, I tore the ball joint boot. Looking through VBP, I found these, Poly ball joint boots.
Next time hit the knuckle of the arm with the nut on about 3 or 4 turns and it will pop down. Saves the boots. If you get longer bolts, I would only go w/10" bolts and make sure they are grade 8 if you buy elsewhere.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I don't know that you did this but try using a ball joint separator and not a pickle fork for this job. Pickle fork is hard to use and not tear the boots.
I cut my FE7 springs..half coil..dropped it 1"..that also increased spring rate somewhat..think I've seen threads on forum where guys have cut 550 springs to lower vettes as well...??? Depends on how much you need to come down...I'm at 26 1/2" to center of fender well...
Thanks VS, thats how I ended up getting it after I tore the boot.
I'm skeptical about 550# springs because I dont think they will bring me down enough... I'm at about 28" in the front, 29" in the rear. I need to go way down.
you can make your own for about 8-10 bucks. use 3/4 x 2" bolts and a 3/4 coupler. slightly drill a recessed spot into the head of each bolt. place between the balljoints placing the tip/ threaded end into the recessd spot, and turn the coupler with a wrench. it will push the ball joint away from one another untill they pop out
In October I decided to lower the front of my 79. With nothing to lose I cut two rounds off the top of each coil spring directly in line with the original end. I put it back together, dropped the car and WOW!, it was perfect! I took it out and ran it through some hard cornering-- no rubs-- no bottoming out--I was very pleased. BTW- I run 245/60 15s on the front. KYB gas shocks, 1 1/4" VBP swaybar.
