B/B oil pressure problem
Old Dec 29, 2005 | 04:40 PM
monzared69's Avatar
monzared69
Default B/B oil pressure problem
I have a potential problem with my b/b oil pressure. I just rebuilt the motor. The oil pressure starts out at 50lbs and drops to 10lbs when it warms up. I'm running 5w 40, The block is 30 over crank was ground 10/10 the oil pump is a standard melling.
Could this be a oil pump gone bad or something worse ? I hate to have to pull the motor but sounds like I may have to.
Thanx Mark
Old Dec 29, 2005 | 05:11 PM
big_G's Avatar
big_G
Verify the accuracy of the gauge with a known good one (remote gauge screwed into the block) before you get too worried.
Old Dec 29, 2005 | 05:27 PM
monzared69's Avatar
monzared69
I have tried 2 gauges and both are reading the same thing.
Mark
Old Dec 29, 2005 | 05:40 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
5W oil is mighty thin. I'd try straight 30wt. Chuck
Old Dec 29, 2005 | 06:28 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
or 10W-30
Old Dec 29, 2005 | 06:35 PM
694speed350's Avatar
694speed350
how about 20-50?
Old Dec 29, 2005 | 07:03 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Originally Posted by 694speed350
how about 20-50?
your oil is too thin. go with the 20-50 castroil should work great.
you are in florida not alaska lol.
Old Dec 29, 2005 | 08:11 PM
Sayfoo's Avatar
Sayfoo
10 # at IDLE is probably ok. On the low end of OK, but probably OK for a well used engine, not a new one. Does the pressure rise when the engine is rev'd up? You shouldn't have to use thick oil in a new engine. Sounds like excessive bearing clearance when warm. You may have to bite the bullet and tear into the engine before you have major damage. May be cheaper in the long run. Good luck. Of course, check everything first--oil filter, oil level, oil pumpm etc.
Old Dec 29, 2005 | 08:42 PM
monzared69's Avatar
monzared69
The pressure does rise when you idle it up,goes to about 25lbs then drops back down. When I assembled the engine I plasti-gauged the whole thing it was well within specs.
Will 30w oil make that big of a difference?
I was thinking about droping the pan and putting in a high pressure oil pump ?
I'm trying to think if there maybe a oil plug left out some where?
Mark
Old Dec 29, 2005 | 08:44 PM
monzared69's Avatar
monzared69
Should I go with 20w- 50 or straight 30w ?
Old Dec 29, 2005 | 08:49 PM
SHAKERATTLEROLL
Old Dec 30, 2005 | 01:22 AM
robert kirk's Avatar
robert kirk
glen is right. This is not an oil problem, its a clearance problem. rev the engine to about 2500 hold it and quickly let off the gas, If the pressure goes up before it drops its bearings for sure. Make sure engine is at temp. you don't need a high pressure, or high volumn pump. the factory oiling system is outstanding. this is just my opi. good luck.
Old Dec 30, 2005 | 07:31 AM
GDaina's Avatar
GDaina
I'm thinking the same
Old Dec 30, 2005 | 07:49 AM
kb2fzq's Avatar
kb2fzq
Before you start ripping and tearing on the engine, a 20-50 oil change is cheap and see what you have then....easy first, difficult later, if necessary..
Old Dec 30, 2005 | 02:07 PM
monzared69's Avatar
monzared69
I'm making progress. I did a oil change with 20w-50 and its starts at 45lbs and holds 20lbs all warmed up. I can live with that.
Thanx for the Help
Mark
Old Dec 30, 2005 | 03:07 PM
kb2fzq's Avatar
kb2fzq
Thanx for the Help
Mark
Actually, my engine goes to 40# on high rev and holds at 20# on idle, 'course it's got 100,000 miles on it, so I'd expect that I guess, last oil change I had 20-50 put in, also, but it's rather moot since I need valve guide seals....but, glad ya saw a difference...might get better as the engine breaks in...
Old Dec 30, 2005 | 05:53 PM
SHAKERATTLEROLL
To B/B oil pressure problem
