POR-15 Paint Question
Old Dec 30, 2005 | 12:19 PM
Kim72's Avatar
Kim72
Default POR-15 Paint Question
Will dot 3 brake fluid affect POR-15?? I was contemplating painting my calipers with POR-15 I have left over but I'm wondering if it's affected by brake fluid. Anyone with experience??
Also, anyone know the color the spindle backing plates are suppost to be?? I'm not married to NCRS but I'm just looking for ideas on what color to use.
Old Dec 30, 2005 | 12:23 PM
76custompaint's Avatar
76custompaint
For the Por-15 vs brake fluid look here
Old Dec 30, 2005 | 01:26 PM
Maine Vette's Avatar
Maine Vette
Not sure how it would deal with the heat either, although they do sell a high temp version of POR-15 for engine blocks and such.
Old Dec 30, 2005 | 02:36 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I hate por 15
Old Dec 30, 2005 | 02:40 PM
Edzred72's Avatar
Edzred72
Talked with a POR tech a while back, and he said regular POR is rated to 300*.
Eddie
Old Dec 30, 2005 | 07:51 PM
Kenny Bonnell's Avatar
Kenny Bonnell
Yellow73SB I hate por 15
What do you hate about it?? I just ordered some to do my frame with, maybe I'd better listen before doing it.
Old Dec 30, 2005 | 08:08 PM
76custompaint
I think the worst part of painting with the por-15 is doing the recoat 3-5 hours later. It's a great product, as long as you do the prep right, make sure to use marine clean and the metal-ready on the frame before you start, it makes everything go very smooth I really have nothing to complain about with it, it's not as easy as a rattle can, but I'll probably never have to do it again unlike if I just spray painted it
Old Dec 30, 2005 | 08:15 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Its not bad. I just Like my hammerite.
Old Dec 31, 2005 | 12:05 AM
mandm1200's Avatar
mandm1200
I used silver POR15 as the base when painting my dust sheilds. One calpier leaked after rebuilding it. The POR-15 didn't stand a chance, it bubbled and peeled off where the fliud leaked.
Old Dec 31, 2005 | 12:10 AM
ltlevil's Avatar
ltlevil
So I assume the hammerrite stands up to the brakefluid?
ltlevil
Old Dec 31, 2005 | 09:54 AM
Joevett's Avatar
Joevett
5th Gear
I am also considering some work with POR15. Now you guys are making me nervous. I am starting with something safe --- seat frames that got rusty.
What's the difference between POR15 and other "rust reformer" products (such as made by Rust-Oleum)?
Old Dec 31, 2005 | 09:26 PM
LemansBlue68's Avatar
LemansBlue68
My buddy did the subframe for his Z28 in POR15 and had a leak in the proportioning valve. The brake fluid leaked all over the frame and wrecked the finish. He ended up pulling and stripping the subframe and powder coating it. It was a lot of work but the powder coat ended up looking better after all. He went with DOT5 fluid after that.
DOT3 fluid is better performing fluid with respect to higher boiling point etc. and better for your daily driver, but DOT5 is hands down better with respect to keeping your expensive paint intact on your hobby/show car. It also doesn't absorb moisture like DOT3 and rot your brake lines over the years.
To POR-15 Paint Question
