What to replace next??
Old Dec 30, 2005 | 08:04 PM
Localbulldog's Avatar
Localbulldog
Default What to replace next??
76 L-48 Coupe
The shop I use removed the rear end for a complete rebuild,replaced the rear wheel bearings both sides (end play set), replaced the e brake pads, replaced the side yokes and lock rings, all u joints replaced.
The shop has been great about it, as a matter of fact he has removed the rear end to check the clutches and fluid twice !
The problem is the right rear still makes a bump and grind noise while turning in a tight radius in either direction.
The trailling arm bushings look great and all the shims are in place.
What do I replace next ??
Old Dec 30, 2005 | 08:32 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by Localbulldog
76 L-48 Coupe The shop has been great about it, as a matter of fact he has removed the rear end to check the clutches and fluid twice !
Sounds like classic diff. if it only does it when turning. Have them replace the clutches and add GM posi lube to the rear end.
Old Dec 30, 2005 | 08:39 PM
Localbulldog
Thats the thing, been there and done that ...................twice. The clutches have been replaced and the diff fluid put in. Is there something else in the rear end that could be messed up causing this?
Old Dec 30, 2005 | 10:14 PM
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
Have you tried making several tight circles in a parking lot in both directions? This will help pull lube up into the clutches. This is a common problem. It will usually work.
Old Dec 30, 2005 | 10:27 PM
rihwoods's Avatar
rihwoods
This may sound to simple,but what about the carrier mount cushion....
Old Dec 30, 2005 | 10:34 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Make sure they are adding the GM additive first and then the fluid.
Old Dec 30, 2005 | 10:39 PM
big_G's Avatar
big_G
I would drive it for a few hundred miles. If noise persists, add 1 more bottle of G.M. posi. additive.
Old Dec 30, 2005 | 11:06 PM
surveyor3447's Avatar
surveyor3447
Default good luck I have been here too
There is a small clip that retains everything in alignment in the center core. one of them was broken when they installed new clutches or came loose putting in the short shaft. changed the carrier and rebuilt once more and worked fine just will not hold the power I am putting out. I need help there.
Old Dec 31, 2005 | 05:42 PM
Localbulldog
I replaced that too. Could it be warped rotors ? Trailing arms ? Everything looks and checks out good but something is making that noise................................... .....
Old Dec 31, 2005 | 06:45 PM
jimmygmartin's Avatar
jimmygmartin
My '68 Vert does the same thing, funny thing is that it never did it before I rebuilt the Diff. I was changing the ring & pinion at a pro shop & decided to get a rebuild while I was at it. Added two bottles of aditive (second one after noticing the noise). Seems to go away with miles and come back after the winter shut-down. I stopped worring about it.
Old Dec 31, 2005 | 09:45 PM
Localbulldog
I like the sounds of that !!
Old Jan 1, 2006 | 12:23 AM
1971corvette's Avatar
1971corvette
Mine rearend makes noise also,only after I took it apart
I am driving it untill the noise goes away,then I will
on it some more.
Old Jan 1, 2006 | 05:56 PM
Localbulldog
Thanks for the help. I'll put some GM Additive in after I take it out of storage.
Old Jan 3, 2006 | 07:15 PM
Localbulldog
Okay, How do I drain and then refill the diff fluid ?
Old Jan 3, 2006 | 09:30 PM
GaryS's Avatar
GaryS
The differentials are drained by use of suction gun to draw out the old fluid and the gun is used to replace with your favorite differential fluid plus GM positraction additive.
Gary
To What to replace next??
